My civic 96 Exi 4-door sedan's battery drains so fast
Old Feb 10, 2010
mah81's Avatar
mah81 is an unknown quantity at this point
Hi all,
I have a civic 96 Exi 4-door sedan with D15Z4 engine.
I could experience fast battery drain. hence could not start the car after 2-3 days. I replaced the battery couple of months back. Sometimes observed faint illumination of car DVD setup panel when ignition switched off. I guessed this fast battery drain happens due to a fault in DVD setup. I used to remove DVD's front panel when the car had parked. But not resolved yet. the Check Engine normally illuminated and went-off after ignition switched on.
Can it be a short circuit of sensors? ECM/PCM?
Can it be a fault in DVD setup?
Could you please help me to resolve it?
Thanks!!!
Old Feb 10, 2010
Re: My civic 96 Exi 4-door sedan's battery drains so fast
first try to fully disconnect any accessories you added other than what the car comes with. see if the drain still occurs.
Old Feb 10, 2010
mah81's Avatar
Hi GearBox, Thanks for the reply.
BTW; Is it ok if I follow this approach to isolate the issue?
First connect the multimeter in between negative terminal of the battery and cabel. then measure the amount of current draws when ignition switched off. (Can you please tell me the acceptable current that needs for ECUs and clocks????). If it draws significant amount of current then remove the fuses one by one...??? starting from Audio out/ECM/PCM fuse?
Old Feb 11, 2010
start by pulling fuses for the extra parts you installed. is it just the dvd player or do you have amps too? its usually not the car at fault. any small drain by the ecu and other electronics should not be enough to drain the battery in a few days. does your battery read the normal 12.5v or so right after driving?
Old Feb 11, 2010
mah81's Avatar
FYI: Extra parts that I have installed!
- DVD player & mirror LCD (additionally works as reverse camera)
- 850W Blaupunkt GT Amplifier and subwoofer
- security system with remote key
Anyway I checked the battery drain by removing Amp power cable (big red wire going to battery +ve) as well. No clue :-(
Recently I found that, DVD player and security system are going through Audio, ECM/PCM Fuse. (ECM reset fuse).
Old Feb 11, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
I am wondering if you have the DVD player through a constant on fuse, if so change it to a key on accessory fuse like the cig lighter.
Old Feb 11, 2010
mah81's Avatar
civicpapi,
I didn't get you clearly.
I pulled the #47 (Audio Unit, ECM/PCM) fuse and observed that DVD setup and security system were not working after ignition switched on. [after engine started]. Isn't it a acceptable wiring for accessories?
Could you pls explain little more? Thanks
Old Feb 11, 2010
civicpapi's Avatar
civicpapi,
What year and model is your car?
Is the dvd player an in dash unit that replaces your stock radio? A quick thought if it is a dash unit, is it possible you switched the 2 power wires, one is red and the other is yellow?
If it is an accessory I would wire it to a switched lead, which means it is only active with the key on. There might be 2 radio fuses, I believe under the dash and the other under the hood. As for the security unit that is ok to wire to a constant on, since it needs power for the led and to function in general, an accessory will drain your battery, say a radar detector etc.
Old Feb 11, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
Keep that fuse pulled and see if the battery drains. If it doesn't drain, then we know it is something to do with your ICE.
Old Feb 12, 2010
mah81's Avatar
it's 1996 4-DR sedan Exi with D15Z4 engine. (Manual)
The DVD player was attached to the dash which replaced the Factory fitted Honda Radio. Additionally 850W Amp and subwoofer were installed. but powered directly from battery, in this case I disconnected power to the amp already.
Old Feb 12, 2010
Awjvail's Avatar
Is the amp drawing continuous power? Is the remote wire functioning properly so that it turns off when the car turns off?
Old Feb 12, 2010
mah81's Avatar
Thanks for replying gentlemen ....
yeah it was drawing continuous power. So I disconnected the big red cable from Battery +ve very first. I think remote wire was functioning properly. As the amp LEDs turned on only after the DVD turned on and played something.
But the thing is after the car turned off, could observe faint illumination in DVD panel display LEDs.. So I used to remove the DVD panel when car turned off. But the battery drain continued ....
Does that sign a fault in DVD player or wiring?
help me... :-(
Old Feb 12, 2010
civicpapi's Avatar
If you see a faint lighting in the unit then it prob it is wired wrong. Did you use an aftermarket wire harness that plugs into the honda one? I would pull the dvd player and double check the wiring. Like I posted before check the 2 power wires one is red and the other is yellow. The yellow on is a constant on (going on my memory).
Old Feb 16, 2010
mah81's Avatar
I just removed both DVD setup and HONDA factory setup (To narrow down the scope :-))last weekend. Right after keeping the engine ON for 15minutes (without running), the battery terminals read 12.93V. After 1 day the car started without any issue. So I switched off the engine and kept for another day. But the following day car did not start. The battery terminals were somewhere around 10V.
Why it was drained significantly after removing all the added accessories except security system?
1. By keeping the engine ON for 15minutes (without running) - Will the charge not enough to start the engine two three times? (May be a stupid question!!!). I thought first attempt consumed significant amount of battery that prevented the engine start by second attempt.
2. Problem with the new battery?
Thanks.........
Old Feb 16, 2010
civicpapi's Avatar
Thanks.........
A couple of thoughts, did this only happen when you got the new battery?
Another thought, double check to make sure you got the right battery. The reason I am saying this is many years ago I went to Sears for a battery for my old firebird and the idiot gave me the wrong battery, so it was under sized for my application and it kept dying on me and even took out my alternator with it.
Old Feb 16, 2010
mah81's Avatar
It was experienced with the old battery when I purchased the car. I thought battery was expired and bought the new battery. The battery was 60Ah. (Most of my EK3 mates using this!!! EK3 2000 same!)
roverben
Jan 21, 2019 05:16 PM
ChristinaVHH
May 10, 2015 03:51 PM
usajags84
May 10, 2015 08:11 AM
tylerginevan
Apr 27, 2015 12:29 PM
civic_gt
Apr 19, 2015 08:15 AM
