CEL misfire on cyl 2 and 4
Old Jan 4, 2010
96coupe's Avatar
96coupe is an unknown quantity at this point
Hi everyone,
I have a problem with my 96 civic. The CEL light came on and the codes are reading misfire on cyl 2 and 4. The problem started about 2 months ago, on cold morning starts it runs really rough until the car is warmed up. After the cars warmed up everything runs fine but the gas milage has gone down alot. I used to get about 550 km's to a tank and now im only getting about 350-400. Its a single cam engine with a 5 spd tranny and about 230k kms. I pulled #2 and 4 cyl plugs and they look good also. Im going nuts trying to figure things out. The tune up was done about 2 years ago when I bought the car. Thanks for any input.
Old Jan 7, 2010
ScottDR's Avatar
ScottDR will become famous soon enough
Re: CEL misfire on cyl 2 and 4
Check your spark plug wire resistance to be sure they are all within specification. Also, at the last tune up was your distributor cap and rotor replaced?
Old Jan 7, 2010
96coupe's Avatar
Hey thanks for the tip, Im going to change the cap, rotor, plugs, wires. Im not sure if they were changed the last time, but Im changing them this time so hopefully it fixes the problem.
Old Jan 9, 2010
96coupe's Avatar
Well, I think its fixed now. After starting it from overnight, things seem to be running nice and smooth. Changed out the plugs, wires, cap, rotor, pcv, air filter and fuel filter. Car seems to be running better, but why would I need a tune up a year into it, I thought tune-ups were about every two years?
Old Jan 10, 2010
ScottDR's Avatar
I wouldn't say every two years. The cap/rotor/wires are good for 100,000 miles (I've personally had several OEM wires go for 200,000 miles with zero problems and still meet specifications). The plugs are every 30,000 miles. My guess is the distributor cap was slightly loose letting in moisture or was contaminated before installing (as it has an O ring to keep it sealed). Or, what plugs did you pull out? I always run NGK because of consistency, but Denso would be my only second choice.
Old Jan 10, 2010
if you use cheap auto store components, then yeah they prolly wont even last a year. stick with name brands like NGK or oem. i cant even count how many "Xact brand" plug wires and E3 spark plugs were being returned sometimes after a few months because they fail so fast.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
jtcavey
Sep 30, 2015 02:18 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
Mannimarco
Sep 7, 2015 10:01 PM
