Installed Intake now Knocking NOISE!! HELP
Old Feb 12, 2010
Civ2000's Avatar
Civ2000 is an unknown quantity at this point
I installed a aftermarket short air intake yesterday and
and now today my car is making a knocking noise whenever I'm in the low rpm range.. My car is running fine and actualy is running better but this noise sounds like ****.. I can't tell where it's comming from, has this happened to anybody else?
Old Feb 12, 2010
Civ2000's Avatar
Re: Installed Intake now Knocking NOISE!! HELP
It's actualy like a clicking noise.. Their wasn't a hole for the breather tube on the intake so I put a breather filter off the engine could that be doing it?
Old Feb 12, 2010
that would not cause the noise, but could ruin the engine over time. put a towel over the intake pipe and close the hood. i bet the noise goes away.
Old Feb 12, 2010
Civ2000's Avatar
What do you mean wrap the intake pipe with a towel? Won't that catch fire and the sound sounds like it's comming from my engine
Old Feb 12, 2010
i just meant as a quick test. alot of those ebay generic intakes hit the hood and make rattle noises. so if the towel fixes it, you need to modify the intake by cutting the pipe so it sits lower. otherwise an intake should not cause any problems. its just air moving thru it to the engine.
Old Feb 12, 2010
Civ2000's Avatar
Wooow i think that what it is because I thought it looked alittle high I can definetly lower it a little bit.. Thank you very much I will try that when I get outta work an hour and let you kno what happened.. Thanks for the help!
Old Feb 15, 2010
originalem1's Avatar
originalem1 is an unknown quantity at this point
Lmao
danace99
23
Jun 28, 2015 08:49 AM
Supramk3
May 11, 2015 07:55 PM
carid
Apr 30, 2015 07:00 AM
bsmiley
Apr 27, 2015 01:27 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
