Alignment question
Old Feb 16, 2010
horent135's Avatar
horent135 is an unknown quantity at this point
Alignment question
I have 97 DX sedan. Everything on my car is stock, nothing is moded. The situation is I'm getting inner wear on my tires, so that means I have negative cambers. I talk to a tech guy, he says I need correction camber kit.. The thing is my car isn't lower or anything, do I really need the correction camber kit or what else can I do?
Old Feb 16, 2010
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Alignment question
Excessive toe can also be the culprit. Have it checked at a reliable shop before committing to something you most likely don't need (like a camber kit). If it's stock ride height my bet is the toe is off (and could be because of a tie rod being worn).
Good luck, and let us know what happens.
Old Feb 17, 2010
Bo97EJ6's Avatar
Bo97EJ6 is an unknown quantity at this point
yea i had some inner wear on my right front tire, come to find out it was the tie rod on that side was worn out pretty bad. i went ahead and changed inner and outer tie rods on both sides and replaced the boots on my steering rack (was already under there so why not) luckily i write service at a dealership so i have great access to smart techs and a nice alignment rack.....riding straight now!
Old Feb 19, 2010
cschneider27's Avatar
cschneider27 is an unknown quantity at this point
def. sounds like Tie Rods...just did mine on the right side...it shook like crazy around 60 mph...come to find out the right outer tie-rod was beat! $18 for the outer...i forget how much for the inner.
Old Feb 20, 2010
zXeX's Avatar
zXeX is an unknown quantity at this point
Is this front or back? All four?
I had excessive wear on the inner tread on the rear.. Went on a 3,000 mile trip a few months ago and destroyed the rear tires... Come to find out my rear trailing arm bushings were Shot and it effected the toe quiet a bit. Both had cracked and fell apart. Bought the bushing Xtractor tool and some decent bushings, installed them, and all is well after a four wheel alignment...
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bsmiley
Aug 13, 2015 10:32 PM
civic98?
Aug 13, 2015 01:32 AM
Dangerousjordan
Jul 28, 2015 08:24 AM
