Synchro Issue -- Synchromesh?
Old Feb 3, 2010
minorsecond's Avatar
minorsecond is an unknown quantity at this point
Forgive me, but I used the search function and didn't find much on the subject here (though I've found a lot elsewhere.)
I've got the 3rd (and fourth) gear synchro issue with my manual tranny and everyone seems to be recommending the GM synchromesh friction modified fluid. However, I've read that the friction modified fluid has been discontinued and everyone was saying that it's the FM formula that helps alleviate the synchro issue for a while. I bought the pennzoil synchromesh fluid and hopefully that will help but I recall people saying that the pennzoil fluid didn't really help like the GM stuff did.
Do you know what people are using these days to help with the synchro problem (other than a tranny job.. I seriously can't afford that these days)?
Old Feb 7, 2010
dnice78's Avatar
dnice78 is an unknown quantity at this point
Re: Synchro Issue -- Synchromesh?
I was recomended the Synchromesh as well, and just went with Honda MTF, it worked just fine.
Old Feb 7, 2010
rednwhite04's Avatar
rednwhite04 will become famous soon enough
If you do some more searching on google or other forums you might find that a lot of Honda people say synchromesh is no good. Don't ask why, I just remember reading that. I run regular 80-90W gear lube in mine.
Old Feb 8, 2010
dnice78's Avatar
Just run Honda MTF
Old Feb 8, 2010
TRIZ's Avatar
I wouldnt put anything in my tranny but honda fluid. Honda MTF FTW.
Old Feb 11, 2010
I found the synchromesh fluid the other day and since putting it in, shifting does seem smoother. The grinds are still there but I've only put around 30 miles on it since then. All of the posts I've read say that it'll take around a couple hundred miles to make a difference.
PiCASSO
Apr 23, 2002 12:38 AM
CIVICTypeRookie
Apr 12, 2002 09:09 PM
droidekaus
Mar 18, 2002 02:06 PM
PiCASSO
Mar 10, 2002 01:34 PM
RiCeGrL
Feb 21, 2002 09:07 PM
