gurggle noise when i shift into first
Old Feb 9, 2010
civic LX 1999's Avatar
civic LX 1999 is an unknown quantity at this point
I have a 200o honda civic LX... manual transmission
When I shift into first, there's a watery gurggle sound... almost like an aquarium bubbling sound. It's short and doesn't continue until I move into first again.
Any ideas?
Old Feb 9, 2010
Re: gurggle noise when i shift into first
if its coming from the passenger side dash area inside the car, its most likely air bubbles in the coolant flowing thru the heater core. either caused if you had a recent coolant flush or if you have exhaust gases in the coolant, from blown headgasket. or a leak in the cooling system can sometimes cause air to build up too.
Old Feb 10, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
How long have you noticed the sound? sometimes it will go away by itself.
If you want to purge the cooling system of air there is a procedure to do it.
Basically, with a cool car (do not remove the cap when the car is hot) take off the radiator cap and let run for a bit and see if you notice any bubbling.
*note I accept no responsibility for this post, the above is just short sequence of what to do.
15EXCoupe
Jul 30, 2015 12:59 PM
estes53
Jul 20, 2015 10:43 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Jul 12, 2015 11:54 AM
fvckbg
Jul 7, 2015 07:08 PM
