2k civic ildeing weird?
Old Nov 10, 2009
Black2kcivic's Avatar
Black2kcivic is an unknown quantity at this point
2k civic ex coupe manually.
When i come to a stop the idle is at a little over 1k then after a minute it drops to normal. Is this normal ?
Old Nov 10, 2009
Re: 2k civic ildeing weird?
idle should be around 700 rpms +/-100 rpms without load. or 650 with load. clean out the throttle body and idle air sensors, then put it all back and do the ecu reset and idle learn. should fix it.
Old Nov 10, 2009
Thanks for the advice, i am not to good with cars but i looked up how to clean the throttle body and did that. still the same problem. I will try an clean the idle air sensors tomorrow and let you know.
Old Nov 11, 2009
Thanks alot man. Cleaned everything and now it is perfect.
Old Nov 11, 2009
cool. you prolly wont have to clean it again for a long time, if ever. usually happens early during the first few years when the engine is breaking in and everything gets messy.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Poopies
Apr 20, 2017 11:36 PM
shaejb15
Apr 26, 2015 07:44 PM
cdt12271
Apr 23, 2015 11:36 AM
SSMatey
Apr 13, 2015 06:09 PM
