- 97 civic lx CEL
- disasemble rear speaker base
- RED wiring change
- Custom Sub encloser / amp rack help
- Convert an air conditioner pump to air compressor!?
- 97 civic wont start
- For Sale. Chicagoland area
- Jammed lock (I hate theives)
- 96 LX AT idling higher
- where can i find a Honda civic manual?
- What color is my car?
- Custom interior
- Have a Question about chip off my bumper
- Could anyone identify this?
- A better way to paint?
- Muffler
- EK3 Jerk - Non Vtec - 1998 EXi
- 98 EK Misreading RPMs
- Small Plastic Cap Replacement.
- Labor day mini mods
- fuel light quiry
- EK3 Mi Gauge Cluster faces
- new to the game and in desperate help
- I need help. Someone please
- Suspension questions
- What would you do if your ATF plug looked like this?
- overheating but why?
- Jacking up a 98 Civic EX (for oil change)
- Headlights and Tires
- help please :(
- Replacing Blaster cannon with stock muffler
- 98 EX A/C Question
- customizing 1996 civic ex interior
- EK9 Horn
- 1996 front bumper replacement help
- ('98 Civic sedan) Replace stock radio?
- OBD-II Protocol for '99 Civic?
- 99 civic air conditioner troubleshoot
- My civic gets 18 MPG!?
- Loose bumper
- ('98 Civic) Repair manual do you recommend?
- RPM/Vtec question on 1998 1.5i LS
- What brakes and rotors do you guys recomend?
- 96 HX Instrument Needle Lights?
- New to cars- new to Honda- new to CIVIC! Need help.
- Would Vinyl Paint over dashboard ruin the value?
- Replace exh. manifold 2000 DX
- 96-98 civics Carbon Fiber Fenders!! Brand NEW!!! GRADE A!! IN THE BOX!!!
- Dummy Lights & Signal indicators
- 2000 Honda Civic Gauge showing 3/4 Overheat but car normal
- Any Good Honda Transmission Techs in the Bay Area?
- Fuel Average
- Stock bass? Can they last?
- Buying Help
- New, just bought EJ9
- Car jerks to the right.
- Water pump/Timing belt opinions. What should i get?
- 98 EX Auto Tranny fluid change questions
- What car seats are compatible for a 98 civic dx sedan
- Introduction and question
- will a SRI or CAI pass inspection in canada?
- 98 EX A/C problem
- New to imports and need help
- Tire options
- my project update
- I just bought a 1999 Civic SI
- Wrong Tranny fluid.
- A.C. can it get colder?
- Horsepower!
- B17A1 build
- Just bought a 98 Fixer Upper...newbie here needing help!
- Are you slammed?
- Need help with my speedo.
- need help!!
- what do you think
- gauge cluster face problem
- 98 d16y5 p1259 wont rev out past 4k
- Do i need a tune??
- Better Gas Mileage???
- carlisle car show
- Funny speedometer
- 98 Civic ex A/C issue
- 96 civic hesitates badly from stop
- Civic 6th Gen Average Mileage
- Shifter stuck
- Vtec..d16a
- Keyless remote operation
- Which Exhaust Manifold/Cat Assembly to Buy?
- Bluetooth Car Deck - Advice Needed
- jack stands
- Civic Si EM1 Lip Install
- 2000 Civic completely ceasing power on acceleration when hot.
- 97 Civic LX codes P1298, P0135, P0141, P0501
- oil pan gasket
- 2000 civic si major tranny problem agin
- Buyers Questions?
- Replacement stainless stock exhaust
- Stage 1 Crower Cam -- Need help on research
- Easy Performance Mods
- a/c charge for civic 96: low side or high side?
- Lower hose keeps leaking - driving me crazy
- Internal Upgrades D16y8
- Does anyone know which model K&N intake will fit a 2000 Civic SE?
- Exhaust Rattle
- power windows
- new car...havent been here in forever
- What would you do if...
- 98 civic lx 4 door
- 2000 EX w/auotmatic tranny
- 1997 Civic HX - A/C comes and goes
- 97 hx
- 1996 1.4 i buy advice
- Alignment question - is the camber/caster NOT adjustable?
- 96 ek hatch questions
- 1999 DX-VP exhaust manifold gasket Q's. Re-installing after being welded.
- Removing after market deck from 98 civic
- Oklahoma- RSX seats modified for EK
- 96 ek hatchback questions. everyone please input.
- 96 EX Original Paint Chipping & Fading
- Gear box?
- F***ed up brakes
- 96 ex manual gauge faces?
- Friend driving '96 black civic gone missing
- Straight Pipe or Cat?
- 2000 Civic Cx Hatch, Add AC?
- My car wont start
- 96 DX Headlight Warning Buzzer
- ignition module
- 1998 honda civic ex exhaust system
- d16-b18c swap
- Someone from NC please buy this!!
- 97 Civic: AC Question
- 96 Civic Hatchback exhaust
- Does my engine have an EGR valve?
- Power window problem. Broken wire?
- Advice- Seems like a good offer...
- Need EXTREMELY BRIGHT reverse lights????
- Project Car?
- Have you experienced transmission issues with code p0715?
- ideas for gaining more power
- Civic 96 questions
- 96-00 civic radiator hose size
- 5w20 in D16Y7 ??
- exhaust? Jardine
- Cylinder 1 random misfire
- suspension
- Muffler and exhaust???
- glazed headlight housings/buffing kits
- 2000 Civic EX B16 Swap Questions
- 2000 Civic EX Tail Light bulbs?
- Is this safe?
- 1998 LX (heating up)
- Newbie engine compatability
- newbie 98 civic ex do not want vtec
- 2000 civic si turbo,
- why would my steering have became loose?
- Cabin air filter... which one for my 97 EX?
- exhaust
- D16 tranny/clutch swap
- Window still trim - where can I find it?
- Civic Si Swap to b18?
- '93 Front Clip
- Anybody put Transmission filter on auto 6th gen civic?
- Compression testing...
- OEM Lug Nuts and OEM Hub Caps - 1996 14 inch
- All seats the same across trim levels?
- RWD 2JZ-powered Civic with S2000 front clip. Is it possible?
- Engine Lacking Power
- Tranny Swap
- Need Suggestion How To Paint Outside Black Trims
- Engine Swap on a DX
- oil pan gasket replacement
- Making my civic look good
- How to fix spoiler light?
- 2000 Honda Civic EX
- Exhaust pipe flange
- 96 civic ex loses power when weather is hot
- body kit for 97 civic hx coupe
- question, i wanna see this
- Engine Trouble
- Should I buy it?
- Barely Failed HC (PPM) SMOG TEST ONLY STATION
- Where can I find a 5 speed B series transmission?
- Helppppp!!!!
- I need to replace manual window crank handle and shaft
- 2000 ex cuts off at 5k rpms read this unique case
- engine was swapped
- Key stuck in ignition in 1998 Civic
- Help with fixing 96 EX windows
- Need help with chassis wiring in rubber conduit to driver door 1996 Cicic EX
- civic over heats please help
- Sunroof Shade
- Fog Lights on '00 Front End
- Vtec Conversion
- source for new tps sensor?
- engineto turbo
- P0303 and P1399 check engine light on, please help
- Scangauge2...has anyone tried it, or will it work on a civic?
- in need of majour help
- Suddenly lose power for seconds
- Can't get oil pan off D16Y8
- quick nub question
- Shaking when Idle
- Whats the deal with the HXs?
- I need exhaust help
- Temperture Guage
- Frustration w/ Door Actuator
- what front clips are interchangeable with a 1999 Civic?
- $70 muffler vs a $200 muffler
- 00' civic si wanted!!
- numerous engine codes....HELP!!!
- opinion on performance coil, wires, plugs
- 1996 Civic ECU Help!
- How to adjust timing on '96 Civic Cx?
- 97 Civic HX hood question
- dual infront of rear tire side exit exhaust
- Biggest Bang for the Buck (Engine Swap)
- stock d16 turbo.
- What needs to be done on '00 Civic LX with 14K miles?
- 1998 ex shuts off at random times
- Advice on doing up my first Civic
- Frankenstein Ls-Vtec
- Need help with 2000 si
- 97 Honda Civic HX - Adjusting valves
- 97 Honda Civic HX Distributor leaking motor oil.
- got a question bout my 24 dollar turbo
- im new!
- Stage 3 clutch/ 8lb flywheel
- Lil assistance
- aftermarket temp gauge questions
- Trans interchange for 99 Si w/B16
- parts question
- engine swap help!?
- Need help fast!
- Exhaust HELP!!!
- AC Compressor
- cooling problem I can't figure out
- head swap
- B Pipe Warranty?
- 1997 civic coupe
- How do i replace rear window and rear quarter panel on 2 door
- Projector headlights WITHOUT halos?
- Zex 59300 or Crower stage 2 Turbo cam?
- helpin the newbie out general info on 98 civic ex
- 97 Honda Civic HX -Check engine light (need advice on 4 Codes)
- transmission from d engine interchangeable?
- Creative ideas to quiet noisy transmission?
- 1999 Civic SI - There's a random switch and I don't know what it does - HELP
- Killswitch/Foggiies?
