Shaking when Idle
Old Apr 8, 2011
JUL3926's Avatar
JUL3926 is an unknown quantity at this point
Shaking when Idle
Hello-
I have a 2000 Honda Civic Ex and recently noticed that it sometimes shakes when I am at say a stop light. Does not happen all of the time. Just once in a while and usually after I have been driving for a while.
It makes me nervous because it just seems like my car will die out. When I press the gas, it is fine and stops shaking.
Any ideas?
Old Apr 8, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: Shaking when Idle
Can you be specific? What kind of shakes? The steering wheel? The whole car? Does this happen when the car is in gear or not in gear? What about when you're braking? Turning? Is the clutch engaged? Does your trunk have a murder victim in it? Be more specific, please
Old Apr 8, 2011
BlueEM2's Avatar
Whachya lookin at?
Clean your throttle body and surrounding valves and sensors with throttle body cleaner and see if that helps.
Old Apr 9, 2011
JUL3926's Avatar
The whole car shakes. My car is an automatic so it happens when it is in drive. Doesn't happen as I am breaking. Starts when I am fully stopped and gets worse if I am stopped for a while. It goes away once I step on the gas.
Couldn't be the murder victim. Took him out months ago
Old Apr 9, 2011
JUL3926's Avatar
Just had the throttle body cleaned. Place said it was super dirty. Hopefully, that worked. So far so good!
Old Apr 10, 2011
Zeferint's Avatar
Autocross Padawan
Glad to hear tbohar's diagnosis is working for ya.
Old Apr 10, 2011
BlueEM2's Avatar
Whachya lookin at?
Even if it doesnt fix it its a great maintenance step and also another major issue you can eliminate. Also usually the cheapest fix so a good place to start If it continues I can lead you other directions but hopefully that resolves your problem!
Old Apr 12, 2011
performanccivic's Avatar
performanccivic is an unknown quantity at this point
Does it shake worse when you put it in drive at the lights, compared to neutral?
What rpm is your needle at when you stop at the lights?
Could just require adjustment (increase) of the idle speed.
Old Aug 5, 2015
amrhamed's Avatar
amrhamed is an unknown quantity at this point
Hey i have the same issue kindly can u explain for me what is the throttle body .. thanks
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
SimpleUser
Apr 24, 2021 02:54 AM
muniorbust
33
Aug 31, 2015 08:59 PM
lyanreindecker
Aug 20, 2015 09:15 PM
amrhamed
Aug 7, 2015 11:39 AM
