engine was swapped
Old Apr 18, 2011
heavyd21962's Avatar
heavyd21962 is an unknown quantity at this point
engine was swapped
I have a 1997 ex that a 2000 hx engine/auto. was put in the car. The ecu is a p2p. The other individual swapped the intake and throttle body from the d16y8 engine. The car is getting fuel and has spark but through my research I believe I am going to need another ecu or just an adapter harness for current ecu. Any help will be appreciated this is driving me nuts. Is there a harness to go from the p2p to the d16y5 engine ?
Old Apr 18, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: engine was swapped
According to http://www.hondata.com/techecuid.html:
P2P = 96+ OBD-2 Civic EX
P2N = 96+ OBD-2 Civic HX
The difference is the vtec activation in the P2N. The HX has Vtec-E, which essentially means that it activates 8 of the 16 valves at ~2800 RPM's and the remaining valves at ~5800 RPM's (for fuel economy) The EX only has the one vtec activation at ~5800 RPM's. I found a thread from clubcivic.com (http://www.clubcivic.com/board/showthread.php?t=92786) and the guy said he used a P2P ecu in his HX and he took it to a shop and they tested it and reported that it worked fine. I don't know if the shop did any modifications to his P2P ecu to make it work for his HX. My educated guess is that since both have vtec activation, and the P2P doesn't have the first vtec activation that the P2N has, the first activation would just be skipped and only initiated at the 5800 RPM threshold.
However, my recommendation would be to get an HX (P2N) ECU to take advantage of the first/second vtec activation as this is one of the many advantages that the HX has. If the other guy swapped the intake and throttle body from the Y8 engine then you should be fine in that regard.
Old Apr 19, 2011
Thanks for the advice. Would I need an adapter harness for the P2N to work with the P2P wiring?
Old Apr 20, 2011
Zeferint's Avatar
Autocross Padawan
Yes, HX engines are suppose to have a 5 wire O2 harness but the EX only has 4 wires: 2 heater wires, 1 ground for the O2 and 1 O2 signal wire.
Old Apr 20, 2011
It would probably be a bit better to just swap out the y8 head and use the current ecu. I have a gasket set and the parts available. Again, thanks for all the advice and help
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Chronic_issues
May 8, 2015 05:40 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
