Replace exh. manifold 2000 DX
Old Aug 5, 2011
311tim's Avatar
311tim is an unknown quantity at this point
Got a crack in manifold, I bring it in, guy takes it out, it's a 1 piece that attaches directly to, but does not include, the cat; he calls Honda and they insist the replacement is a 1 piece that is not separable from the cat. Car was manufactured in Canada and sold new in Massachusetts but is now in California (and sticker says it is within emissions clearance for Cal.- plus it passed smog test here last time). So now I apparently have to buy the "two-piece" unit for $600 rather than the unit without cat that costs $400. Or do I? Anyone had this experience?
Old Aug 5, 2011
lazlong's Avatar
Re: Replace exh. manifold 2000 DX
According to the online catalog you should have the cat in the manifold. Is there an O2 sensor sticking out of the manifold? Where ever the sensor is is where the cat is- either in the manifold or in the exhaust pipe.
Old Aug 6, 2011
Sgould's Avatar
Sgould is an unknown quantity at this point
I just had problem with the cat in our 2000 LX, Rock Auto sold both the manifold and cat together. The problem I am having 4 weeks later is a couple of the nuts loosened up on top of the manifold and it is running rough. Should this smooth out again now that everything has been re-tightened?
Old Aug 6, 2011
lazlong's Avatar
Short answer- yes. If it doesn't smooth out then try resetting the ECM/PCM. To reset the ECM/PCM: with the ignition OFF, remove the backup fuse in the under hood fuse box for 10 seconds.
Old Aug 6, 2011
311tim's Avatar
Thanks, but nope- the cat definitely remined under the hood while we held the manifold in our hands.
Old Aug 6, 2011
lazlong's Avatar
Then you probably have the EX exhaust (cat is under the car). Can you take pics?
Old Aug 7, 2011
311tim's Avatar
The station put it back together so I can't get a picture; when he had the manifold out and in his hand it was easy to spot the cylinder holding the cat (or is that cylinder itself the cat?) by simply looking down from above the engine. The VIN shows the car as an LX, though I haven't found that info anywhere else.
mrohitredd
18
May 14, 2015 07:35 PM
What_It_Do
May 10, 2015 05:31 PM
oqjoi
May 9, 2015 10:31 PM
mievil
Apr 28, 2015 11:02 PM
thesushiboy
Apr 12, 2015 02:54 AM
