96 civic ex loses power when weather is hot
Old Apr 23, 2011
LopPolo's Avatar
LopPolo is an unknown quantity at this point
hi.. i just recently bougth a 96 Honda civic EX with 130xxx miles. i started having problems with it.. it seems like when the weather gets hot and after driving it for a few minutes it starts to lose power gas pedal fells heavy and i get rough idle. it has never died on me but it shakes.. this never happens at nigth when the wheater is cooler the car runs so fast and smooth. i just recently changed spark plugs, cables, distributor cap and rotor, oil changed and i still have same problem.. and i have no Check Engine ligth.. i hope some of you can help! thanks
Old Apr 23, 2011
Re: 96 civic ex loses power when weather is hot
go to a autoparts store to get the codes read - they do for free.
Old Apr 25, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
you cant read codes if the check engine light is not on, some short ram intake can do that, where you suck in hot air, and when the air is not cool the combustion isn't strong,
the light and heavy pedal feels check out your throttle body.
Old Apr 25, 2011
either that your idle air control could be dirty
Old Apr 26, 2011
LopPolo's Avatar
thanks guys for your comments.. the gas pedal wont feel heavy at night.. this only happens during the day when is hotter. and its spring so it's not 116 degrees like at summer im scared that in the summer it will get worst. it has a aftermarket akimoto cold air intake.. not sure if that could cause the problem. i get no check engine light and the light works because i can see it when it does the test when i start the engine. please help!!!
Btw it has a 5 speed manual tranny.
Old May 3, 2011
chazual's Avatar
chazual is an unknown quantity at this point
check your air filter make sure its clean. and btw you can check codes without the light being on. these are stored codes that the pcm/ecm (i dont remember what honda calls it) is keeping an eye on. the pcm wont throw a check engine light until it happens a few times usually twice. but there could still be codes
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Blaster30
Apr 22, 2015 12:21 PM
darwin-t
Apr 18, 2015 09:29 PM
deus-ex
Apr 13, 2015 12:29 PM
gabrown2
Apr 11, 2015 08:22 PM
