Compression testing...
I attempted to do a compression test on my d16y8 and when i was done i had surprisingly high numbers:
dry: 180, 180, 195, 190
wet: 190, 195, 200, 200
Car has 134k miles. When i did this i had one of my friends crank the engine until i saw the needle stop moving and it took anywhere between 3-5 seconds. We disconnected the ignition and removed the spark plugs and while cranking, he was holding the brake pedal down so no fuel was sent to the engine.
I would like to know if we did this right (cranking till the needle stops moving) and what the normal compression for my engine is. I tried to researched how long the crank has to be turned but everyone has a different opinion.
Thanks
Thanks
Re: Compression testing...
Yeah, till the needle stops is fine. Usually a 5 count will do.
Don't know proper psi for your model, sorry. All the cylinders are within 10 psi of each other so you should be fine.
more than likely carbon buildup on the pistons and combustion chamber is causing higher compression. if the car drives fine, i wouldnt worry. i think around 140psi is normal. wouldnt hurt to do an auto-rx.com treatment in the oil.
if you can look through your spark plug holes and see carbon build up or if you think you have carbon build up i would go and get an injector cleaning. the **** they run through the injectors is real good for cleaning up carbon deposits and it could pro-long the life of your engine. thats just me tho, i would rather the engine run normal and sluggish then with higher compression then it was designed to take
. Don't mean to get off topic, but how do i get rid of the carbon buildup? I tried some fuel additive (I think it was Lucas) but it didn't seem to work. I also drive under 3k rpm most of the time to save gas and i know that causes more carbon buildup.
Thanks
just follow the auto-rx treatment schedule (3-5k miles with the additive, then change oil again and drive another 3-5k for rinse). youll be amazed how much faster the car feels.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Sep 27, 2015 11:33 AM
NROD315
Sep 12, 2015 02:46 PM
darwin-t
Aug 15, 2015 10:51 AM
2000, 200s, buy, c6th, civic, compression, dry, generation, gsr, high, honda, kit, ompression, test, wet
