View Poll Results: How to fix a few electrical problems on my 96 EX
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Help with fixing 96 EX windows
I need help on how to fix, if possible my power windows. I have a 1996 Civic Sedan EX. The driver side and back left window have a mind of their own. The back left window is now stuck in the down position. The drivers side window only works if I have the door open and roll it up/down. Also, the back right door is locked shut. I would appreciate any suggestions. I am stuck with a window that is down and would like to be able to fix it before it rains or someone decides they "need" something of mine to take out of the car. Thank You.
Re: Help with fixing 96 EX windows
I'm confused as to the poll option... but if the windows are stuck and won't respond to the switch then you need new door window motor(s). check hondapartscheap.com or hondapartsnow.com
Thank You. I don't understand the poll option thing. I am just trying to find any help with the questions that I have and I found this website. My Civic just has a ton of electrical problems.
could also be a stuck window switch in the down position or not making contact.swap it with a working switch from the other door and see if it functions normally.
Blazz
May 25, 2015 10:56 PM
werdnahall
May 17, 2015 11:37 AM
drhawkinz
May 16, 2015 11:39 AM
Ronin
Apr 18, 2002 10:14 PM
