96 LX AT idling higher
Old Sep 19, 2011
408civiclx1996's Avatar
408civiclx1996 is an unknown quantity at this point
ok so i just got my girlfriends 96 lx up and running after sitting for 3 years.
at first it would fluctuate idle from 1000-2000 rpm and now it just sits at 2500 rpm and after a drive up to 3500.
now i heard it could be a few things like the idle control valve,
a throttle body sensor, or even a temp/coolant sensor. can anyone help!?
Old Sep 20, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: 96 LX AT idling higher
Check for vacuum leaks, could be the iacv valve, pvc valve, you may also have mixed up the plugs by accident that connect to the IACV and TPS. You could also try resetting the ECU and the doing the idle relearn. (yank the ecu fuse with the car off & keep it out for 30 seconds or so)
SimpleUser
Apr 24, 2021 02:54 AM
napkins
Aug 12, 2015 04:20 PM
Martinez8o5
Jul 31, 2015 10:58 PM
Dangerousjordan
Jul 30, 2015 11:19 AM
