96 DX Headlight Warning Buzzer
Old May 26, 2011
teahou's Avatar
teahou is an unknown quantity at this point
Howdo. I left my headlights on this morning, and later realized it was because the buzzer didn't go off when I shut off the car with the lights still on.
Can anyone tell me the buzzer is, or if it is run off a fuse? Thanks.
Old May 26, 2011
Re: 96 DX Headlight Warning Buzzer
i think the actual buzzer is in the gauge cluster and hardly ever goes bad. more likely the driver door trigger is bad. does the dome light come on when you open the door? do you get the beeping sound if you leave the key in the ignition and open the driver door with the engine off?
Old Jun 1, 2011
teahou's Avatar
I checked, and the door switch is fine (dome light comes on and the 'key-in' chime sounds. I noticed the dash lights quit working at the same time as the "lights-on" warning buzzer quit, could there be a connection??
Old Jun 6, 2011
JackedByJack's Avatar
JackedByJack is an unknown quantity at this point
well take your gauge cluster out un plug everything and plug it all back in make sure u keep note of everything and where it is
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
