Advice- Seems like a good offer...
Old May 18, 2011
db9's Avatar
db9
db9 is an unknown quantity at this point
97 Civic EX
$1650
It has:
No collision
4 cyl
Automatic
2 dr
New head on engine
headgasket replaced
new cooling system
new rack and pinion
new timing belt
new water pump
It needs:
New windsheild
New regulator for the pass window
I thought it sounded like a fair price and I just wanted to know if others thought so too.
Old May 18, 2011
mike98's Avatar
mike98 is an unknown quantity at this point
Re: Advice- Seems like a good offer...
If it has no (or minimum) rust and under 200k miles then YES. If you go see it have a compression test done (on top of the regular checks)
Old May 18, 2011
MindBomber's Avatar
Live for the Twisties
Since it has a new head gasket you definitely should have compression tests done.
Old May 19, 2011
db9's Avatar
db9
Just found out that the car is being held pending payment of the work that was done. It's been there since February and the owner has until month end to pay and reclaim the car.
Do you think the shop would have done a compression test due to the work I listed below?
I suppose I could call them back- They were pretty helpful in shedding a little light on the situation/owner I'm dealing with.
Thanks for helping!
Old May 20, 2011
db9's Avatar
db9
Compression test were done after the work- reading 130-150.
I found a formula and according to it, these are good numbers.
Old May 20, 2011
lazlong's Avatar
Really should be 10psi difference for a fresh rebuild. 20psi is a high mileage engine and if the heads were done right then it may have a minute amount of loss somewhere else. I'm thinking you should be ok for now.
Ask the shop how much they want if he doesn't sell it. If it's less than $1650, talk him down to what the shop wants to release it. Then take him down there and make them release it to you. I imagine $1650 is the cost with all those repairs but, you never know. Doesn't sound like too bad a deal.
Windshield will cost you $250-350 for mobile windshield repair. Passenger switch is usually a broken wire or the master switch.
Last edited by lazlong; May 20, 2011 at 02:16 PM. Reason: I forgot an O. Can you guess where it was? lol
Old May 22, 2011
DaveMK1's Avatar
DaveMK1 is an unknown quantity at this point
Sounds real fair to me. bought my 96 hatch for 3500 with nothing wrong with it and only 120k on it
Old May 27, 2011
db9's Avatar
db9
Well, I bought it- $1200 after seeing how badly it was treated.
Before I left the lot I had the shop do the front brake pads and rotors and also the passenger window regulator.
I took it from there to another shop and had the windshield replaced and driver door lock fixed.
Then it went to be detailed and have the carpet dyed.
Turns out this cars was much worse than the guy led on.
Looks like it went through a hail storm. It has minor scratches and dents all over the thing. Lastly it was filthy beyond belief.
I'm just shy of having $2000 into it after all repairs. The A/C doesn't work but since I bought it as a gas saver- well that will help too . It needs a new compressor and I've been quoted $550 to do it. I probably wont do it unless my husband gets the part and does it himself.
My husband has been out of town, so your comments and others I've talked to have made this buying experience [on my own] easier for me.
Old May 27, 2011
db9's Avatar
db9
I meant to include the other new things it has:
Radiator
Radiator fan
Fan relay
Hose from radiator to engine
Coolant temp sensor
Thermostat
Old May 27, 2011
lazlong's Avatar
If you get a new compressor I recommend a new one. Re-builds and used usually don't last that long, if they work at all. Just my experience.
Go here for new OEM discount parts:
http://www.hondapartscheap.com/southbay/jsp/home.jsp
http://www.hondaautomotiveparts.com/
http://www.bkhondaparts.com/billkay/jsp/home.jsp
https://www.hondapartsunlimited.com/index.php?p=home
czarlun
Jun 20, 2015 08:55 PM
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
