Fuel Average
Hi,
I just bought a 2000 Civic DX. The motor is a 96 with only 40K in it. The car runs fine. I am getting only 22 mpgs. 35 psi tire pressure all around. I do 70 highway 30 city miles. No CEL's. I know I should get around 30+ mpgs.Would a tuneup (plugs, wires, air/fuel filter, caps and rotor) take it that far?
Thanks
Thanks
Re: Fuel Average
I'd check your plugs and see what they look like. I have a '99DX and it averages between 37-42 mpg.
I just did rotor, cap, and plug wires.
The cap and rotor didn't look too bad and the plug wires were about at a half life still somewhere around 12k ohms. My car has 175 000kms or just over 100k miles
So see what you can see with the spark plugs and test the plug wires with a multimeter under 25K ohms is within spec. Inspect the cap and rotor. Other wise it's more likely an issue on the fuel side.
Re: Fuel Average
Have done the tuneup. (Plugs, wires, rotor, cap and fuel filter). Improved the mileage by 2-3 mpg. Its giving around 24 mpg mixed use and 30mpg straight highway. I found the a big crack on the manifold around the o2 sensor. have ordered the replacement. let's see if the new manifold/cat boosts the mileage.
cwisenbaker06
Aug 19, 2015 04:29 PM
GritzNGravy
Aug 19, 2015 03:03 AM
Civicircus
Aug 6, 2015 11:58 PM
alxz310
Jul 30, 2015 12:18 PM
Green02civic
Jul 27, 2015 10:48 PM
