d16y8 bogging out while accelerating
Old Dec 1, 2009
b4nkshot's Avatar
b4nkshot is an unknown quantity at this point
so, i've been having this problem for a while on my 97 ex. i've looked all over forums and came up with nothing. while i'm driving (with my 02 sensor plugged in) it will bog out during accel.. The 02 sensor is brand new. When i unplug the 02 sensor it runs fine. it's a d16y8 with a header, pipe, and cold air intake. I'm getting ready to turbo it so i need to figure out this problem before i can tune. Please help!!!!
Old Dec 1, 2009
Re: d16y8 bogging out while accelerating
are you sure its the right sensor? cause the wrong one will cause all sorts of problems. not having an o2 sensor will still allow the car to run, but not its best for gas mileage.
Old Dec 2, 2009
b4nkshot's Avatar
I got it from napa.. this is the second one I've had from them.. first one did the same thing so i took it back and got a new one... still the same problem. I'm wondering if it could be a wiring issue.
Old Dec 2, 2009
okay well that tells me its the sensor if youre constantly having issues. i would recommend a BOSCH sensor (which is actually a repackaged oem NTK sensor that hondas use). prolly advance auto has em, maybe some other place.
Old Dec 2, 2009
b4nkshot's Avatar
that's what kind i have. should i just say screw it and get a wide band?
Old Dec 2, 2009
well no, then you'll really have problems. the ecu wont be able to do anything with a wideband, esp if your car came with narrowband (most cars).
Old Dec 2, 2009
b4nkshot's Avatar
okay, rule out that it's the wrong sensor. Have you ever heard of a car doing this?
Old Dec 2, 2009
could also be fuel delivery problem. clogged injectors or low fuel pressure, which would explain bad accel.
Old Dec 12, 2009
CivicAK's Avatar
CivicAK is an unknown quantity at this point
dirty air cleaner?
Old Dec 19, 2009
bmxjosh25's Avatar
bmxjosh25 is an unknown quantity at this point
around wat rpms does it bog out at?? like as u start to go or wat??.. my car does it around 5000 rpms .
juicetayne
Sep 30, 2015 11:02 AM
Bruce2
Sep 27, 2015 08:45 PM
winanthony94
Sep 25, 2015 09:05 AM
chiquita.banana
Sep 24, 2015 09:42 AM
dantheman42
Sep 4, 2015 01:10 PM
