Ignition...key pls!
Re: Ignition...key pls!
Does it not turn all the way to LOCK?
If it does turn all the way to lock, does it not release the key?
Which?
Got a less worn out key to try? Try a new key that wasn't duped, have it cut by the key code. Might just be a worn out key.
Which?
Does that mean you can or can't turn the cylinder to LOCK? Your answer wasn't clear to me.
And yes, keys wear out. Just grind all the teeth flat on one and try your locks.
Here ya go, check this out: http://www.justanswer.com/uploads/Ho...005918_zzz.pdf
Touge
Sep 23, 2015 10:51 PM
Touge
Ottawa
Sep 22, 2015 11:58 PM
Touge
Sep 22, 2015 11:55 PM
Touge
Ottawa
Sep 22, 2015 11:52 PM
Touge
