My 2000 civic si keeps dying on me while i drive. Urgent help please!
Old May 14, 2010
775civicsi's Avatar
775civicsi is an unknown quantity at this point
Unhappy My 2000 civic si keeps dying on me while i drive. Urgent help please!
Hi, i have a 2000 honda civic si that i resently did a engine swap on. Right now im having problems with my battery. I took the alternator and battery to autozone to get them tested and they tested out that they're still good but when my battery is fully charged and i drive around for about 15-30 mintues my car starts to die on me and the battery starts to die. Im moving to california soon so can any one please help me out if u have a solution to my problem??? thanx
Old May 24, 2010
Don Boosted's Avatar
Don Boosted is an unknown quantity at this point
Re: My 2000 civic si keeps dying on me while i drive. Urgent help please!
From you've said so far it sounds like the alternator is toast.
Has this 15-30 minute battery life happened a couple times? A functioning alternator continuously recharges the battery, in other words it keeps it from dying every thirty minutes.
I had a bad battery that tested fine at Autozone, the tests aren't always accurate.
Old May 24, 2010
ekcivic719's Avatar
ekcivic719 is an unknown quantity at this point
make sure all of your grounds are connected to check i would start the car with the hood open at night and check for sparks it happened to me and was a simple fix to tighten up a bolt/nut
Old May 24, 2010
RonJ's Avatar
RonJ will become famous soon enough
Check whether 7.5A dash fuse 15 is blown.
Old Jun 1, 2010
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
check the connector that goes to ur alternator
then check the battery terminal and trace ur wires
it could be loose somwhere
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
