2000 Civic door won't open
Old Feb 22, 2010
grundan's Avatar
grundan is an unknown quantity at this point
here is the lowdown. yesterday my wifes civic drivers side door will not open from inside or outside. The power locks seems to be working, the little handle thingy will travel up and down when you press the switch. Any ideas? I'm guessing I will just have to rip off the inside panel which will be a pain since I cant open the door. Just wondering if anyone had ever had that problem and what the cure might be? When I tear off this door panel, is there a easy way to remove it?
2000 civic lx, 5spd, sedan.
Old Feb 23, 2010
cschneider27's Avatar
cschneider27 is an unknown quantity at this point
Re: 2000 Civic door won't open
1998 Honda Civic LX 5 spd sedan here, and my rear driver's side door wont open. The lock won't go up or down, and it will not open. Let me know if you get this...I don't really see a way to get the door panel off with the door closed unless you like to tear **** up
Old Feb 23, 2010
grundan's Avatar
no answers...??? i've got a buddy that has some of those interior trim tools. i guess ill take it over to his shop and try and get the panel off and figger out what is broke. good luck with your rear door. have you tried a slim jim to unlock it?
Old Feb 27, 2010
arice's Avatar
arice is an unknown quantity at this point
Found this forum randomly searching for this problem in my sons 1998 civic. Did you get a fix for this other than the obvious ripping off the door panel? I know the actuator is not engaging the unlocking device somehow? I was wondering if there was a way to get the door open with a slim lime device at the latch?
Thanks for your help in advance.
rcolosi
Apr 29, 2015 07:48 PM
civic_gt
Apr 19, 2015 08:15 AM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
silvervtec01
Nov 4, 2001 06:56 PM
