Build a B16A2
Old Apr 18, 2010
ntobis's Avatar
ntobis is an unknown quantity at this point
Build a B16A2
Ive been a lurker for a while. I have a 1999 si with 70,000 miles that i want to start building. I use this thing as a daily, but id like to make some bulletproof power NA. My performance marks are 180-200 hp, and 120-140tq with rock solid reliability. I need the suggestions of you masters of the B-SERIES. Thanks
Old Apr 23, 2010
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Build a B16A2
CTR cams are a nice gain. Also go with the ITR intake manifold and a cold air intake. For exhaust stick only with mandrel bent and I have found 2.25 works very well. Let us know what you pull on the dyno, it should make your goal.
Old Apr 23, 2010
ntobis's Avatar
Re: Build a B16A2
Thanks for the advice. I bought the car with an AEM intake, DG header and catback. It also has A/C delete, and pulleys. I also ran across a jackson racing supercharger that i could get hold of pretty cheap. An words of advice on that route?
Old Apr 25, 2010
ScottDR's Avatar
Re: Build a B16A2
I personally do not liked forced induction on an engine designed for NA. It will never last.
Old May 3, 2010
LVSL3PR's Avatar
LVSL3PR is an unknown quantity at this point
Re: Build a B16A2
NA = Reliable
Boost = More Power
A super charger is the best option for reliability if going the boost route, and it makes probably the most usable power, although im sure others will contend this. With your goals in mind though it should be easily doable NA without any problems.
Dave Brabant
20
Oct 6, 2015 12:44 AM
