civic idle problem
Old Oct 20, 2008
kirk198127's Avatar
kirk198127 is an unknown quantity at this point
Arrow civic idle problem
i have a honda civic 1.4i 8valve t reg its started with a idle problem its bin like this for 2wks and its embarasing now..
it keeps hunting between 1,000 rpm and 2,000rpm every 1-2 seconds can any one help and point me in the right direction please
dont wana take it to honda dealer its 55quid to plug into a dam computer thats daft i recon and not reasonable
help anyone would be gratefull
Old Oct 23, 2008
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Re: civic idle problem
https://www.civicforums.com/forums/1...n-driving.html
Old Oct 23, 2008
imtek9's Avatar
imtek9 is an unknown quantity at this point
i would really check the vacuum if i was you, sounds like a bad pcv valve or a leaky hose somewhere. you can spray some carb cleaner near the lines and listen for rpm changes to find leaks but be careful you dont burn your entire car to the ground lol you pcv valve is supposed to rattle when you shake it, if not then they about ten dollars to replace from napa
Old Sep 5, 2009
rhoran89's Avatar
rhoran89 is an unknown quantity at this point
I am having the same problem with my civic 1.4i. I was told by mechanic that it was the throttle body so I replaced it with 2 others from scrapyards and still have the same problem! Its revving between 800 and 2000 rpm when idle after it warms up. Does anyone have a solution or any suggestions of what to try?
Old Jan 30, 2010
jithendrasanjay's Avatar
jithendrasanjay is an unknown quantity at this point
iam using civic ek3 1999 model. recently i got this problem, normally it ws 500 rpm in idel, after this problem when i transmit to drive rpm comes down , some times it cause to stop the engine. if i put back to neutral positions then rpm comes back to 500. Recently i fixed tv dvd whooper system to my car and that audio mechanic fixed a switch to the subwooper, don.t know some thing happen from that electrical disturbance, please advice on this matter. thanx
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
beneditti
Jan 15, 2016 12:31 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
