remote starter troubleshoot
Old Mar 7, 2009
butch33's Avatar
butch33 is an unknown quantity at this point
I have a 99 se sedan with only 96,000 km's (hoping to get another year out of it)--I've owned it since new
I had a remote engine starter installed a few months after buying it and it has worked without any problems up until a month or so ago --so thats almost 10 years without a hitch .
I changed the battery in the remote a few times over the years and changed it when this problem arised without it making a difference in the problem
any tips on what to look for ?
also -parking break light is staying on .I checked under the hood and the brake fluid reservoir is about a centimeter below the 'minimum'' line .What type of brake fluid should I be using to top it up with dot4 ? dot 5 ?
I'm going for a routine service on monday so I'm not sure if I feel like buying a jug of brake fluid if all it needs is a topping up of less than an ounce when it can be done by honda on monday .I suspect only being below the ''min'' line by a centimetre wont be a big deal if I keep my eye on it til monday .I realize the fluid being low could be a sign of different problems (front brake pads low on mojo ,cylinder leak )
nice forum
Old Mar 8, 2009
bumpincivic00's Avatar
bumpincivic00 is an unknown quantity at this point
Re: remote starter troubleshoot
maybe your hood pin isn't getting a good ground anymore...do you have alot of crappy weather that would cause it to corrode that fast?
Old Mar 9, 2009
butch33's Avatar
well, I'm in northern climate here in canada so I suppose it could corrode quicker than elsewhere
SammySC
121
Apr 7, 2017 07:43 PM
JetsterDajet
52
May 8, 2016 12:11 AM
Nalmonte
Sep 28, 2015 01:10 PM
Luluharp
Sep 27, 2015 11:56 AM
azuraT
Sep 8, 2015 02:53 PM
