Removing Front bumper
hey, im new here, dunno if this is the right section to ask this question but anyway. where do i start? there are the plasticscrew like things as you lift up the bonnet.. where do i go from there? and i want to remove the grill also. cheers
Re: Removing Front bumper
Yes, you are correct in those plastic screws. You also must remove the two bolts along the bottom of the bumper, where it meets the black splash sheild. There are also one phillips screw where the bumper meets the fender on each side. After those few items, it should slide forward and free. Be careful not to scratch it! The grill comes off after the assembly has been removed (it's all one assembly). Good luck!
Hoagey
Lighting
Jun 13, 2015 01:07 PM
Hrddrvs
Apr 11, 2015 11:22 PM
