Cooling Fan and AC
Old Aug 21, 2010
fatsodoctor's Avatar
fatsodoctor is an unknown quantity at this point
Cooling Fan and AC
Is the radiator cooling fan supposed to run while the AC is on? My cooling fan is developing a tendency to come on late, and it doesn't come on when I turn the AC on.
The AC's fan comes on.
Just looking for a confirmation that the cooling fan on a '99 Civic should be on as long as the AC is on.
If it is supposed to be on while the AC is running, and it isn't, might I be looking at a bad relay?
(I've already replaced the thermostat, the fan switch, the coolant sensor, and the radiator. The fan works--I've tested it to the battery, and I've also jumped the ground connection to the fan switch. The fan just doesn't seem to turn on when it should.)
Old Aug 21, 2010
02civicsi02's Avatar
Low and slow!
Re: Cooling Fan and AC
Are you running hot or something. I dont think the radiator fan is suppose to run the hole time the ac is on. The ac fan should always be on with the ac on though.
alinaray
18
Aug 24, 2015 01:04 PM
MrOldskool
Aug 18, 2015 09:58 AM
FutureCivicOwnr
Aug 11, 2015 10:59 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
