Brake Fluid
Old Oct 19, 2010
mnea's Avatar
mnea is an unknown quantity at this point
Brake Fluid
Having brake master cylinder replaced at shop and I assume they'll need to flush and replace the brake fluid. I have ABS...and Honda Service Manual says:
"Always use Genuine Honda DOT3 Brake Fluid. Using a non-Honda brake fluid can cause corrosion and decrease the life
of the system."
Just curious if most of you go with the Genuine Honda DOT3 or some other?
And how much brake fluid should I need to replace the old?
THANKS!
Old Oct 19, 2010
Kennykid2002's Avatar
Kenny the Ricer
Re: Brake Fluid
I just use the yellow prestone dot 3 fluid found everywhere
the $5 quart should be more than enough to flush your system
Old Oct 19, 2010
mnea's Avatar
Re: Brake Fluid
"Hi Temp" or not???
Jul 12, 2015 11:54 AM
OptimisticWay
Jul 10, 2015 04:31 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
General 7th Gen
Jul 9, 2015 10:17 PM
Causemo
Jul 5, 2015 06:42 AM
