Convert to 4 Disc wheel???
Old Jul 20, 2010
crosses's Avatar
crosses is an unknown quantity at this point
Question Convert to 4 Disc wheel???
I have it in mind to convert my 1998 Honda civic EK from a 2 disk wheel rear drum brake to a 4 disk wheel, disks on front and back like fast cars.
What would I need?
Old Jul 24, 2010
kcanoy's Avatar
kcanoy is an unknown quantity at this point
Re: Convert to 4 Disc wheel???
rear trailing arms from an integ. direct bolt on so it should be pretty easy
Old Jul 26, 2010
CheeseFrog's Avatar
CheeseFrog is an unknown quantity at this point
Pretty much this ('94-01 Integra). Swapping the entire trailing arm is easier than just changing out hubs for the disc versions. On mine the parking brake cables were a tiny bit shorter than the Civic ones, so it caused my rear pads to drag all the time.
Old Jul 27, 2010
crosses's Avatar
So what your saying is that I can Just go to a scrap yard And get all the backend parts for an integra between 94-01 and it'll just fit? Also does it matter if its 2dr or 4dr?
Old Jul 29, 2010
kcanoy's Avatar
nah shouldnt matter. my dad has a 4dr integ and i compared my trailing arms to his and they were the same. i had the same problem like cheesefrog. my ebrake cables were a tiny bit short but i didnt put all the cable mounts back on leaving some slack so the rear pads arent making contact all the time
Old Jul 29, 2010
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
you i used a 96 integra rear disc on my car about 5 years ago. just bought new rubber hoses and e brake cables from the dealer. good to go bolt rite in. and if your civic isn't a ex you will need a new master cylnder because its to small otherwise and you will wanna change the brake proportioning valve. to the si or integra one.
Old Jul 29, 2010
crosses's Avatar
Question Re: Convert to 4 Disc wheel???
So basically when am done with the switch, when I press brake, all 4 wheels will respond? instead of 2. Or will the rear brakes only work with the hand brake???
Old Jul 29, 2010
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
Use the e-brake cables from an Si and you won't have the length issues. Also recommended to change the proportioning block to one from a 4-disc equipped vehicle. Just get an Si one, it drops right in
Also, try the search feature conveniently located on your internet browser
https://www.civicforums.com/forums/4...elled-out.html
http://honda-tech.com/showthread.php?t=641639
http://hondacrx881.tripod.com/discbrakes.html (extremely helpful diagram)
http://www.hondashowoff.com/forums/s...ad.php?p=70063
Old Jul 31, 2010
CheeseFrog's Avatar
I was going to do this until I found out the Si proportioning block had the same part number as the one on my '98 DX hatch. So depending on what car you're swapping the discs to, you might not even need to do the proportioning block.
Old Jul 31, 2010
CheeseFrog's Avatar
Damn, why didn't I think of that? Good idea
Old Aug 7, 2010
Mavrick272's Avatar
Yeah, I believe the EX has the same porp. block as the Si, too
Old Aug 7, 2010
crosses's Avatar
Could someone please list out the name of all the parts the are included in a backend and which I need for the swap????
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
breanna_17
Jul 21, 2015 04:01 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
Theshwartz35
Jul 17, 2015 11:13 PM
OptimisticWay
Jul 10, 2015 04:31 PM
