timing belt replacement-2nd time
Old Jun 28, 2010
1stackmack's Avatar
1stackmack is an unknown quantity at this point
Thumbs up timing belt replacement-2nd time
99' civic LX, 4dr, automatic. Changed timing belt at 95K, with water pump & other belts (dealer). QUESTION: When should I have this timing belt changed? There is 160K on the clock right now. NYC hard earned miles. All maintenance has been done on-time or before scheduled time frame. Any info, much appreciated.
Old Jun 28, 2010
02civicsi02's Avatar
Low and slow!
Re: timing belt replacement-2nd time
Timing belts need to be changed bout every 100k, so you probably got bout 40k left before a change.
Old Jul 29, 2010
bacpacker1513's Avatar
bacpacker1513 is an unknown quantity at this point
New to the forum and hope this is in the right thread, no intending to hijack thread.
I just bought a 98 EX last week. It has 110K on it. Looking at the records I have access to, it appears that no timing belt change was ever performed. Do all the civic's have a 100K recommended belt change? Are they interference engines? Where is the danger point on these 120K, 150K, or does everyone hit these right on time?
Old Jul 29, 2010
ronaldo9's Avatar
Do your belt asap. You don't want to risk it breaking and costing you more in the long run.
Old Jul 29, 2010
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
Yes and yes.
Old Jul 29, 2010
Having never worked on a Honda before, how big of a deal is changing out the timing belt? What other items should be changed at the same time? Are there good aftermarket vendors to get the parts from, or do you just use NAPA, O"Rielly's, Auto Zone, or the Dealership's? What kind of price would you expect to pay for the dealer to perform the change?
Old Jul 29, 2010
Low and slow!
You can get then from autozone or the others. And if you take it to the dealership they will rip your but off bad. The timing belt change is fairly easy actually. When doing this you should change the water pump also to get it out of the way while you are at it. This is a timely process but its not to hard.
Old Jul 29, 2010
All 3 belts, timing belt tensioner, water pump all at the same time. You need the special crank shaft tool to remove the crankshaft bolt. http://www.amazon.com/Powerbuilt-648...0421334&sr=8-1
Dont even try it without that tool and 2 breakbars, search on you tube for how to vids.
mattdoc
Mar 14, 2017 12:10 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
