Starting Problems and High Idle 96 EX
Old Oct 18, 2010
ik694's Avatar
ik694 is an unknown quantity at this point
So far I have replaced the battery, starter, battery ground cable, distributer, plugs, plug wires, and fuel filter. I am having trouble starting once in a while. The car will turn over but just wont start. If i continue to try to start it, it will always fire up but sometimes takes 5 min. The problem is most frequently first start of the day, or after a short trip to a store or something and then i try to start again within 5-10 minutes.
Also after these hard starts i occasionally have a high idle problem, my normal idle is about 750 RPMs and when this happens it slowly climbs to about 2K RPMs. After about 1 mile of driving it goes back to normal.
Im out of ideas anyone have any suggestions.
Old Oct 18, 2010
ik694's Avatar
Re: Starting Problems and High Idle 96 EX
Also had a compression and leak down test done. Compression was 168,165,165,165. No leaks.
Old Oct 18, 2010
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
clean the throttle body its probably full of build up.
mikemc422
Aug 9, 2018 05:41 PM
vtechcivic
Apr 21, 2015 06:58 PM
black2k1vtec
Dec 6, 2001 09:49 PM
OoSiLvErCiViCoO
Nov 14, 2001 11:35 AM
OoSiLvErCiViCoO
Nov 14, 2001 06:21 AM
