My Honda seems to have the Hiccups??? Any ideas??
Old Sep 17, 2010
Civicnewby's Avatar
Civicnewby is an unknown quantity at this point
Hello. I have a 99 Civic, 5spd standard. Its the 1.6ltr. I just got the car. My problem is with acceleration. When I BEGIN accelerating, or if I'm under any kind of load, the engine seems to cut out a little. Its like it hiccups a bit when I give it gas. If I just accelerate at a normal pace, it does not happen. If I hit the gas at higher RPM's it does not happen. If I'm on a hill, or there are people in the car, it does the hiccup. Also, it does not idle totally even. Its not a bad idle, but its not great either.
My check engine light was on until yesterday also. I unplugged the battery to put my radio in and the check engine light never came back on.
Someone suggested I use injector cleaner, which I did. It did help a little, but not totally. But someone also suggested the timing belt! Its due in another 15,000Kms.
Any thoughts??
I'd hate to have the belt break, that would be terrible. I'm going to change it anyway, but I'm not sure thats actually my problem.
Thanks so much!
Old Sep 17, 2010
lazlong's Avatar
Re: My Honda seems to have the Hiccups??? Any ideas??
Sounds like a dirty throttle body or malfunctioning IACV (Idle air intake valve).
Old Sep 19, 2010
Steven21's Avatar
Steven21 is an unknown quantity at this point
im about 95% sure its not the timing belt the engine would have a loud tick all the time as long as your engine is running and you would know something isnt right. but it sounds like a dirty throttle body start there then come back if that doesnt work
Old Sep 19, 2010
02civicsi02's Avatar
Low and slow!
You should have got the code read when it was on. Go to a auto parts store and get it read any way it could still be stored. And have you checked your spark plugs, plug wires and distributor cap. There could be corrosion on the distributor cap.
Old Sep 20, 2010
Mad Dog Tannen's Avatar
Sounds like a fuel injection problem. Probably a bad sensor somewhere. Maybee TPS or 02. Get that check engine code and it will point you in the right direction.
Old Sep 30, 2010
Civicnewby's Avatar
It was a faulty ignition wire. Brand new, whodda thunk it??
Old Oct 1, 2010
Usually is something simple. Ignition wires come bad from the factory more than you might think. Glad to hear you got it fixed and for cheap!
Old Feb 4, 2011
madpuku's Avatar
madpuku is an unknown quantity at this point
Hello everyone.
I have an 02. civic ex and i have the same problem. The difference is that the hiccups start only when the engine is getting hot. My check engine light is on since i have the car and every time I have a new code reading, my last reading was 131 on the first o2 sensor and 420 on the second one. The problem was that they told me that i have a misfire on the reading and it might be an injector. What are my solutions what should i do first?
Old Feb 5, 2011
Steven21's Avatar
Originally Posted by madpuku
Hello everyone.
wrong forum yo
LionSpratt
Jan 29, 2017 11:07 PM
pheaton
May 4, 2015 08:26 PM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
Bartkat
20
Feb 19, 2002 01:29 PM
