ek window problem
ek window problem
So i have a 2000 acura 1.6el (pretty well an ek civic), and for the past while, almost every time after i start the car none of the power windows work. After it's been running for 5-10 minutes, they work fine. Any ideas?
Re: ek window problem
Sounds like a bad master switch or loose connection. Pull the switch from the driver's door and look for loose connections. If no loose connections, replace master switch.
http://www.acuraoemparts.com/delray/jsp/home.jsp
Locate the power window relay (in under dash fusebox ?) Check the #s printed on the case... then see if any of the other relays used are the same # and swap the 2 as a test.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
beveragemp
May 25, 2015 07:11 PM
timpan
May 18, 2015 07:06 AM
