PDA
View Full Version : Exterior
  1. Sunroof Problems Episode 1
  2. Bushing in wiper linkage gone/loose in 2001 Vi.
  3. 2001 Honda Civic exposed to rain open driver window loses ALL power when cranking HLP
  4. Hit dead animal, muffler and catalytic converter are no longer attached?
  5. 2003 Civic Coupe Hood Latch
  6. Spoiler
  7. 7th gen civic headlight brackets the same for coupe and sedan?
  8. Driver's side door lock issue
  9. water in my trunk.. how to diagnose source?
  10. Part Compatibility
  11. Anyone near me who paints
  12. How much paint will I need
  13. Honda rear trunk emblem
  14. Help - Trunk leak around deck lid hinge?
  15. Replacing door + trunk locks - are they the same?
  16. Need door panel. 05 coupe.
  17. Coupe door
  18. Stupid, Stoopid, Stew-pid me.
  19. Rear defrost
  20. Deer damage 2004 si
  21. Will a 2005 Si hood fit 2004 LX [solved]
  22. 2004 civic lx
  23. Wipers behaving strange
  24. Tail Lights & Head Lights for 2004 SiR EP3
  25. 2005 Leak
  26. I’m need of New headlights
  27. trunk leak troubleshooting
  28. Fixing rust - undercoating
  29. Slight leak when washing car or raining
  30. Sunroof Drain Tubes [solved] and leak sources
  31. Under the hood insulation question
  32. Auto window feature
  33. Is it paint or old plasti dip
  34. Ep marker lights
  35. 2003 Civic Driver door panel seperated from door
  36. Moonroof Rattle
  37. Moon roof wrench does not fit
  38. I think I broke my hood latch......
  39. I'm missing this lower engine cover. O5 Civic Sdn LX
  40. Looking for CIVIC EM2 2004 1.7i VTEC ES Headlight sprayers (european)
  41. Rust near front jack stand support
  42. Spoiler repaint - replacement adhesive?
  43. 03 Honda Civic
  44. Replacing trim between windows and doors [solved]
  45. I messed up… hood won’t open
  46. Can I hammer it out?
  47. 2004 Honda Civic ex driver side door water leaking [solved]
  48. Aftermarket tail light install wiring help [Solved]
  49. Removing Trunk Floor Drain Hole Cap
  50. 2003 EP2 Radiator Support Question
  51. Are 3 door and 5 door 7G hatch front fenders interchangeable?
  52. Bumper and hood fitment
  53. Any Way To Straighten This By Myself?
  54. DIY window tint
  55. Warning
  56. Hood Bolt Question!
  57. Door lock switch
  58. 2001 civic rockers rotted.
  59. Unusual Front Logo Size
  60. Rear Wiper Fell Off
  61. 2001 and 2005 doors and fender interchange?
  62. 2004 Honda Civic Restoration
  63. what type of repair is needed here?
  64. Wheel wells
  65. Turn signal
  66. How to seal door handle from weather?
  67. ‘03 EX: Trouble opening driver’s door from inside
  68. Hole in floor pan, freaking out
  69. 04 Civic LX - Keyless entry broken?
  70. 2002 EX: Broken window an opportunity to fix my actuator?
  71. Will the bumper fit
  72. My doors don't lock...
  73. Whistling noise -- front passenger area
  74. Can’t open the trunk with the key!
  75. Radiator support help/advice
  76. Front end help
  77. Snapped rear door handle
  78. Only one DRL works, other side has low voltage
  79. Deer Collision...a 1st in 20 years
  80. Drivers door stuck ... Civic 2004 Hatch
  81. I can't open the hood on a Honda Civic 2005 LX
  82. Window Trim/Belt molding
  83. How are the rubber strips on the roof installed?
  84. Latch and actuator
  85. 02 civic rain guard
  86. Rear door handle replacement diagrams
  87. Sprung driver's door - lots of wind noise now
  88. 04 Civic: Can't get Hood Up
  89. Headlight Assembly - Best Off The Shelf Option
  90. Help painting gods!
  91. 2004 Civic trunk leak
  92. Ep front swap with em or ek front
  93. Wang (rear spoiler) help needed
  94. 04 Civic Coupe - 05 Civic 4Dr Part Swap?
  95. Door lock troubleshoot
  96. Looking for 2002 hatchback 5 doors weatherstrips.
  97. 2004 roof molding replacement after paint job
  98. grill guard/push bar for ep3
  99. Hoods
  100. 2002 Civic Si 2 dr coupe
  101. Mirrior housing
  102. Coupe and sedan trunks
  103. Best cheapest way to push out crunched trunk?
  104. Will missing roof rubber trim cause a leak?
  105. What part is this????Frame or reinforcement bar??
  106. Oreilys paint
  107. Replaced the cylinder and the lock still won't turn
  108. Front bumper help
  109. Need a "How-to" for replacing Hood Latch
  110. Remove side view mirror innards from housing
  111. 2005 Acura EL Indicator light part #?
  112. Roof skin
  113. Hood Latch broken due to rad support cracking
  114. door seal
  115. driver-front sunroof drain tube union separated
  116. Painting a replacement part - Paint Match - use Duplicolor brand or similar?
  117. lock switch problem
  118. 04 civic door.
  119. 2004 Civic Coupe Water Leak Driving me Crazy!!
  120. 7th gen manual to power window swap
  121. Driver Rear Window Problems
  122. Civic 52 plate 2001. Issue with central locking.
  123. 2004 SE the top of the window defogger doesn't work
  124. 2004 Civic SE - 3rd brake light not working/can't get bulb out
  125. Replacing metal strut across engine bay
  126. How to manually adjust dipped beam? mk7 sport
  127. Best way to replace cardboard trunk liner?
  128. Window regulator Si HB
  129. Replaced side view mirror and now it's making a ton of wind noise
  130. 3 windows stopped working
  131. Automatic Doors Locks won't work (not the actuator)
  132. 2002 LX sedan door won't latch / catch
  133. Radiator support assembly replacement
  134. Advice Needed For Underbody Rot
  135. Driver's door won't latch
  136. Hard to get key in door lock
  137. 2003 Civic interchangabuility
  138. 02 Honda Civic worth fixing?
  139. Honda civic 2001 dx-sedan rear defroster
  140. How to replace Honda Civic 2005 Front Panel
  141. What happens if my sunroof tubes are clogged?
  142. Window troubleshooting
  143. Driver side door check strap
  144. 2002 Civic EX fender front driver side painted black?
  145. Heated mirrors
  146. 2001 Window Weather Stripping
  147. Help!! Keyfob part number for 2003 Civic LX
  148. Lock issues
  149. Passenger door lock
  150. EP3 rear windshield wiper fluid nozzle
  151. passenger window
  152. 2003 Civic HX convert to Power Windows with 02 Civic lx donor car
  153. Cant find a part number for headlight support bar
  154. Need a pic of trunk/fuel door cable routing in trunk
  155. 2002 Honda Accord and Civic
  156. just bought 2001 Civic ex need help
  157. 04 EL water in trunk
  158. Window fell into door and is stuck
  159. Side mirror replacement, paint match
  160. Plastic clip connecting rod to door handle
  161. Rust on back window panel
  162. Need Help With 2002 Honda Civic - Power Window Not Opening
  163. 2004 LX bumper hanging on by a prayer. Any way to secure it?
  164. Power Door Lock - Driver Side Issue
  165. Door Issues Grr..
  166. Ballpark: Cost For Fixing This Dent?
  167. disable 30 second auto lock
  168. door locks are being funny
  169. Power Doors problem.
  170. Temperamental door locks driving me crazy!
  171. Side Mirror Switch Illumination
  172. '02 SI tail light assembly removal
  173. Headlight bulb
  174. Bumper cover
  175. Door Lock Issues
  176. Windshield washer sensor
  177. Trunk lever not working!
  178. Window Problems?
  179. Vent window replacement
  180. Door Lock
  181. ever change sunroof seal?
  182. Mirror adjusting only up+down - No left+right
  183. Arggg! So pissed. TRUNK Wont stay CLOSED
  184. Remote locking doesnt work... locks dont go up or down. But when using a key they do.
  185. IS it worth it to try and repair a damaged bumper?
  186. Mirror
  187. hood latch hood latch help
  188. Freakin' froo frag windows...
  189. Problem w/ stripped plastic screws at the bottom ends of front bumper
  190. How to silence your trunk , the CHEAP way
  191. Remove taillight tint
  192. Sideview mirror fix
  193. Anyone ever change a door lock actuator?
  194. Driver's Door Lock stopped working
  195. trunk wont close
  196. Door Lock is broken
  197. Help pls! Door handle replacement
  198. Bumper mounts.
  199. Fuel fill door won't open
  200. Door won't open from inside
  201. broken fog light lense
  202. water inside car - windshield help
  203. Hood vandalized!
  204. I hit a cat - Crack on front bumper!!!
  205. Moonroof wont vent all the way on its own
  206. 01-02 or 03 civic bumper fit on 04 civic?
  207. OEM side skirt problem
  208. superglue/loctite on exterior paint...how do i get it off?
  209. Slow power window help
  210. windshieldcrack
  211. window shakes when closing door
  212. keyless entry not working!!! help
  213. Anyone know the Cost to Repair Back Bumper?
  214. Rattling noise on driver side door
  215. passenger side door is messed up
  216. fog in back
  217. Squeak in hood hinge
  218. WINDSHIELD WIPERS SUCK!
  219. TRUNK RATTLE LIKE WHOA
  220. Rattling is BACK!
  221. my window rattles alot ...
  222. Flap on fuel door getting stuck open??
  223. dealer installation of my license plate scratched my paint - warranty?
  224. stock spoiler came loose
  225. Anyone Else's Doors Leak??
  226. Door Problems.....
  227. Nevermind, the power locks work now (strange)
  228. ANyone else have a problem opening their gasoline cap door?
  229. Fog lights from Wal-Mart...?
