Remote locking doesnt work... locks dont go up or down. But when using a key they do.
Old May 13, 2007
J Smith's Avatar
J Smith is an unknown quantity at this point
All ive ever used was the remote to open and lock my car but, for some reason it no longer works.
The alarm can be turned on and off so its not the battery in the remote. The actual locks within the car dont go down or up. But, when using the key to open/lock the car it works...
I cant keep doing this as it holds me up
whats wrong with it?
Old May 14, 2007
J Smith's Avatar
Re: Remote locking doesnt work... locks dont go up or down. But when using a key they
noone knows why this is happening?
Old May 14, 2007
hvc's Avatar
hvc
hvc is an unknown quantity at this point
Does the door lock if you lock it from the door inside? If it doesn't work then it's your actuator. If you can lock them from inside, then i'm not entirely sure. do a search of the board and you'll find something. It's a common problem with the 7th gen civics.
Old May 15, 2007
J Smith's Avatar
i can push them down from the inside...
Old May 15, 2007
CraigW's Avatar
Need more info.
How do they work by the switch on drivers door ?? Listen for noises when attempting. Anything else not working ?? Do they all lock if you lock the drivers door by key ?
Old May 16, 2007
greeen01civic4d's Avatar
hey, i had this problem on my 02, its the lock actuator on the drivers door, it controls the locks on both doors, its like 25 bucks at honda, but its a bitch to install, took me like 2 hours to do, cuz u gotta take the internals of the doors apart, but everything works after i installed this part.... hope it helps
Old May 26, 2007
J Smith's Avatar
http://www.hondaautomotiveparts.com/...gry5=DOOR+LOCK
# 375100 032 1 ACTUATOR ASSY., L. FR. DOOR LOCK ?
Do I need both left and right?
Old May 27, 2007
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
Try Left only first ... if it doesnt fix it ... RIGHT also :-p
Old May 28, 2007
J Smith's Avatar
im gonna have to do both because both locks do not work...
The left does not control the right... They are independent.
Old May 28, 2007
Alpha 5's Avatar
Is this an aftermarket lock kit? It does not sound like your electric locks are stock.
Old May 28, 2007
J Smith's Avatar
It is not aftermarket... Its stock remote/keyless entry
Old Jun 6, 2007
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
ok listen to this clearly...as they have said already its the "door lock actuator". buy them for each door from www.majestichonda.com you'll find them the cheapest there. you do not have to buy the whole lock assembly as some "incapable" users on this forum could not get the actuator out of the lock assembly but its only held in by philip screws you can take it out and replace it.
There is also a DIY for replace the actuator so search for it on the forums.
It will take some time to do but you'll enjoy your locks again.
Just follow the DIY exactly as it is.
Old Jun 14, 2007
phi5's Avatar
phi5 is an unknown quantity at this point
You're not alone with this problem.. I've just placed an order with honda on the entire lock assembly. I will replace mine this upcoming week and hopefully my car will lock and unlock as before.
Old May 31, 2019
engineenigma's Avatar
engineenigma is an unknown quantity at this point
Page not found.
Old May 31, 2019
Colin42's Avatar
Originally Posted by engineenigma
Page not found.
What page? How to do it? Where to buy them?
Old Jun 1, 2019
likely the majestic honda link in post 7. They've updated their site quite a few times since 2007. Hell, they've changed it a lot in the past few months.
visit www.hondaautomotiveparts.com
>select car year, model, trim, & transmission
>>click "body & air conditioning"
>>>click "door locks" (if sedan, choose applicable "front" or "rear" variant)
>>>>crtl + f, type "actuator assembly"
JD101
Jul 19, 2017 10:59 AM
Steven Corns
Jun 10, 2016 09:35 AM
boosted2cam
Exterior
Feb 2, 2010 12:02 AM
varner88
Sep 1, 2006 09:32 PM
chokingvictimva
Jul 23, 2006 07:28 PM
