lock switch problem
Old Mar 5, 2019
greg8829's Avatar
greg8829 is an unknown quantity at this point
Question lock switch problem
2001 civic lx. just added keyless entry. locks work fine with fob. had to replace drivers door actuator to get it to work.
the problem I have is that the switch on the drivers door will lock the doors when pushed down but not unlock either door when pushed up.
I don't hear a solenoid click or the actuators even bump. already swapped with a spare switch and no difference. fuse 16 under hood is good.
where is the relay?
Old Mar 6, 2019
Colin42's Avatar
Re: lock switch problem
broken wire in the door harness?
Old Mar 6, 2019
OE/stock Honda keyless, or aftermarket?
OE: functions are controlled by the MICU
Old Mar 6, 2019
greg8829's Avatar
stock keyless. but this problem occurs even when the keyless module is removed. though the locks work fine with the keyless fob just not with the switch. is there a relay somewhere. looking for broken wire is the last thing I will do. where is the micu?
Old Mar 6, 2019
There are no external relays for power locks.
MICU is built into the underdash fusebox.
Got any other odd electrical gremlins happening? Dome/courtesy lights, wipers, AC, door ajar/lights reminder beeper inop, BRAKE indicator stuck on?
ElCivic2002
Feb 4, 2014 08:36 PM
billythebassman
Jan 27, 2013 02:41 PM
prasansk
Nov 21, 2012 08:47 PM
03TxCivic
Oct 8, 2006 05:31 PM
dups
Dec 29, 2003 10:43 PM
