Broken Keyless Entry
Old Aug 29, 2006
03TxCivic's Avatar
03TxCivic is an unknown quantity at this point
My keyless entry has recently stopped working and I was just wondering if any of you guys have had this problem. My car is a 2003 ex and it has like 42k miles. Before I had little bullshit stop working like the tap lights, but now its the keyless entry which I use every damn day. I cant manually lock the car inside, but i can still lock it with the key.
Old Aug 30, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
So wait, does the switch work inside the car with the door closed? To lock the door from the inside pull the handle and push the lock down @ the same time. Do your power locks still work?
Old Aug 31, 2006
streetglower's Avatar
is it all doors or only one door that cant be locked from the inside?
Old Aug 31, 2006
03TxCivic's Avatar
The drivers side door only can be locked from the outside with the key. I cant manually lock the door from the inside. The passenger door can still be opened with the automatic lock switch. And it can be locked manually by a passenger. The keyless buttons dont work at all. When i press the keyless button, you can hear the locking mechanisms in the doors attempting to open, but nothing happens. I think its electrical and since my car just got outta warranty it sucks.
Old Aug 31, 2006
Its probally the actuator to be honest. If you can Hear the doors trying to click open then the electrical is ok. At least to our knoweldge. I think the lock mechanism is hooked directly into the same part for the door latch. So it comes as on piece. PM your email Ill send you the PDF of the electrical schematic for the power locks. Stupid question does your car still beep when the door is open?
I thought I had the diagram. Let me look.
Last edited by nj_represent; Aug 31, 2006 at 10:54 AM. Reason: Automerged Doublepost
Old Sep 1, 2006
03TxCivic's Avatar
The car door still beeps when the door is open with the keys in the ignition.. I can manually lock the drivers side door when the car is on, but when the car is turned off it wont let me push the lock down.
Old Sep 1, 2006
you have a faulty door actuator. if you can lock/unlock a door with the switch but the other only manaully with the key then its a bad actuator.
Old Oct 8, 2006
mikewong's Avatar
mikewong is an unknown quantity at this point
i am having the same issue. if i wasn't taking a nap inside my car, i would have never noticed it. does anyone have instructions on how to fix this problem? (ie. stripping the driver side door and actually fixing the actuator)
Old Oct 8, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
behind the inside door handel theres a lil plate.. pop that off with a screwdriver and remove the two screws
the bottom of the armrest pulls off (use a screwdriver)
theres 2 screws under it.. take those out
where the plastic meets the metal door theres 2-3 clips on each side.. just pry it apart and then lift up gently
reach behind the plastic piece and disconnect the window controls (wires)
cut/peal back the plastic
handaautomotive.com sells keyless kits and has PDF instilation instructions for free on the site.. dont get the kit from them cuz you dont need everything just get the single actuator from yer dealer/ebay/whatever
somewhere theres a more detailed door pannel removal diy but thats the basics
h4ldol
Apr 24, 2017 08:16 PM
Ziggy1999
Oct 15, 2015 07:56 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Dave Brabant
Sep 9, 2015 08:11 PM
