Door won't open from inside
Old Sep 26, 2005
Jenglass's Avatar
Jenglass is an unknown quantity at this point
Is there a way I can fix the driver door by myself? Basically, I have to roll the window down and use the outside handle to get out. The inside one stopped working.
Old Sep 26, 2005
streetglower's Avatar
More then likely the rod that connects to the door handle got disconnected from it. Assuming your have a 01-05 civic, at the top where the door handle is on the inside, remove the little box in there and behind it remove the screws and there is rod that should connect to the door handle, it is a shinny rod and it connects into a plastic clip that can be moved around. look and see if it is still connected, if it isnt, see if it is hanging there and just reconnect it, otherwise remove the door panel and position it back up to the top.
here is a pic to help you, look at the second or so pic, there is the rod you are looking for. http://www.7thgencivic.com/forums/sh...d.php?t=149120
Old Oct 21, 2009
nmastereal's Avatar
nmastereal is an unknown quantity at this point
Re: Door won't open from inside
bump
I am having this same problem except i opened it, and the metal rod is not disconnected from the inside handle, i can pull the inside handle completely out, how do i reconnect it to the other part it should be connected to? pictures would help please
Old Oct 22, 2009
CraigW's Avatar
^^^ Is the long metal rod still connected to the handle ?? If so you will need to pull the panel and see where it came loose (it goes over to the latch assembly near the edge of the door)
Old Oct 22, 2009
nmastereal's Avatar
do you have a pic of the latch assembly? i get the panel off but i cant get under the metal frame where the rod goes
Old Oct 22, 2009
nmastereal's Avatar
i have an 03 civic lx
Old Oct 22, 2009
CraigW's Avatar
Here is a thread (the actuator mounts to the latch. https://www.civicforums.com/forums/1...-actuator.html
You should be able to look in and see where the inside handle rod goes into the latch. It is near the top. If the rod is loose from the latch...? the rods end length will match closely with where it came loose from.
Old Dec 16, 2009
nmastereal's Avatar
i know its been a long time but i have been away, i managed to get it in the right position but it doesnt stay there, when you pull the handle it comes off the latch. I dont know what to do
Old Dec 16, 2009
is that plastic holder broken?
Old Dec 17, 2009
nmastereal's Avatar
it looks more like a ledge rather than an L shaped holder
Old Dec 17, 2009
nmastereal's Avatar
the metal lever is what im trying to place it on but it seems like im putting it on an object that looks like that, when i make that go down the door unlocks but it wont stay there.
Old Dec 17, 2009
CraigW's Avatar
The blue drawing looks like the inside handle ?? or is that somewhere else ??
The linkage rods are connected to other parts in a couple ways, but for the most part have plastic clips of different colors that swivel and clip over the rod to secure it in place.
Old Dec 17, 2009
nmastereal's Avatar
i wish i could get a better look at where it goes.
what i drew is the metal rod that comes from the handle into the door opening mechanism. all i can barely see is a plastic lever looking like the blue wedge (its really white plastic) and when i put the metal rod (arm) onto it and pull the door unlocks but it doesnt stay firmly
Old Dec 18, 2009
CraigW's Avatar
The inside handle should have the plastic clip that swivels around and is clipped onto the metal bar once it is in place in the handle.
Old Jun 10, 2010
nmastereal's Avatar
the metal bar is connected to the inside handle but i can just pull the handle with rod out so i need to find where the rod connects and i cant see ****.
Old Jun 14, 2010
Vail67's Avatar
Vail67 is an unknown quantity at this point
I'm having a very similar problem on my 1998 Civic. The interior door handle doesn't engage/work when it's on, but when i unscrew it and pop it out and physically pull it, it opens the door. From everything I can see, nothing is loose. Any ideas? Thank you!
Old Mar 2, 2023
CDubb's Avatar
CDubb is an unknown quantity at this point
14 years later.... figure it out?!? lmk
Old Mar 2, 2023
If you can, pull apart the interior door handle mechanism and post up a pic. There's a metal bar with a 90-degree bend at the end that interfaces with the handle. That's the part that Vali67 is talking about pulling to open the door. If you're in the same exact predicament, I'm willing to bet the problem is narrowed down to the door handle assembly itself
the pic part is so we can see what you're looking at to see if we can tell you what's broken
Old Mar 2, 2023
CDubb's Avatar
Yes, that's still attached to the handle itself and the rod is not just hanging loose. It still lightly moves the actuator it seems but not enough to open from the inside only. I'm guessing a new actuator is needed but I'll post asap.
churchie
May 28, 2014 06:32 PM
drmcstford
Exterior
Mar 5, 2013 01:46 PM
droolander
Nov 26, 2010 12:20 PM
01SOHCcivic
Jun 25, 2003 08:01 PM
