Painting a replacement part - Paint Match - use Duplicolor brand or similar?
Not sure what sub-forum/ thread to post this in....
My apologies if posting this here is incorrect.
I had a drivers side mirror clipped off on my '03 Civic Ex Sedan.
Swapped it with one from my 'parts car' but it's a different color.
Are any of the aftermarket cans of spray paint any good?
I'm considering trying Duplicolor brand.
I need to match color "B92P-4" aka "Nighthawk Black Pearl".
Also if using the above is there any prep work to be done before painting?
And is there anything to do after painting (like a gloss coat or sealer of some sort??).
Re: Painting a replacement part - Paint Match - use Duplicolor brand or similar?
I don't know if Duplicolor is any good but black is usually easy to match but shows any flaws. You will have to sand the old paint and apply a coat of primer before the color coat. I don't know if it will require a clear coat but since it says 'Pearl' my guess would be yes. If the new paint doesn't have the gloss you expect then it needs a clear coat.
Dr Krieger of Modification
The colour wont be a problem, it's the clear coat and finish which will give you issues if not done right.
-sand original paint (you can leave the colour coat on but make sure it is rough enough to paint.
-spray colour match coats
-let dry to touch
-spray a two part "2k" clear coat (the kind that has a primer button on the bottom). This will harden to car paint spec.
-let dry for 1 month
-wet sand 2000 grit
-buff and polish to perfection.
good luck.
-let dry to touch
-wet sand 2000 grit
good luck.
klam
06-17-2002 04:35 PM
