2003 Civic HX convert to Power Windows with 02 Civic lx donor car
I bought a parts car for my HX because I had to replace one of the doors and the parts car was cheap with lots of useful parts.
I swapped the driver door and the harness for the power windows hooks up in the stock location but it is not working.
Does anyone know what else is needed from the LX to get the power windows working? If it is an extremely hard process I can always install the stock manual internals into the door instead.
Re: 2003 Civic HX convert to Power Windows with 02 Civic lx donor car
Your car harness probably does not have the necessary wiring for power windows even though the harness connected to the door.
You got more wiring to do if you want it to work.
2003 Honda Civic HX swap doors with power widnows from a 2002 Civic LX
My 2003 Civic hx was hit on the side by a plow truck and i purchased a 2002 Civic lx coupe parts car.
I swapped the driver door because it was damaged. The door from the 02 LX has powered windows. It seems it connected to the stock port on my HX but the power windows are not working.
I would really like to get the power windows working.
I have both full cars so I can swap over any parts that i need.
Any advise would be very helpful!
Under my dash the fusebox does have a spot for power windows and the fuse is there. I am not sure if there are any wires behind it. I can check today.
Power windows would be extremely nice
Re: 2003 Honda Civic HX swap doors with power widnows from a 2002 Civic LX
Probably swap the floor-body harnesses that the doors connect to, then see what happens. At least look into it, see if that's what needs to happen.
Blaster30
Apr 22, 2015 12:21 PM
dooner24
Apr 14, 2015 07:51 PM
