2001 Window Weather Stripping
Re: 2001 Window Weather Stripping
The strip that's peeling and exposing shiny metal should be found under "molding" in the drop down menu.
Satin black spray paint is an option too.
Thanks for the pic, I was looking for that also, preferrably b/f winter.
How do you replace that strip?
Mine looks like there is a gap between the strip and the painted top edge of the door, so may have been reinstalled incorrectly, or bumped and damaged (?) A tiny silver tab is visible under the strip in the gap, the strip is loose when the window is rolled down, and not sealing 100% when window is up.
After you get the mirror out of the way, and maybe the chunk of vertical trim at the rear (or you might be able to slide the horizontal trim out from under it after it's pulled up, IDK), it should lift/pry straight up. New part should come with the clips (#10) attached to the trim. Study how the clips work before trying to yank the old trim up.
They aren't really designed to seal against the glass. If they do that's great, but they don't have to. Doors are designed to allow water to flow through and out the drain holes at the bottom.
At $24 online, I am going to order it this week, thanks for the pic, especially if the clips come with it. I may have to take it to a body shop, or find a diagram in a Honda manual on how to remove the other pieces of trim around it. Otherwise the chances of damaging another piece are really good.
peihondaguy
Nov 11, 2015 10:06 AM
cgriffin51
Oct 31, 2015 03:43 PM
