Side Mirror Switch Illumination
Old Jun 17, 2011
dubosegriffin's Avatar
dubosegriffin is an unknown quantity at this point
Greetings,
I have a 2002 HondaCivic EX sedan. The side mirror switch that is adjacent to the moonroof switch on the left hand side of the car near the change holder does not illuminate. Is it supposed to illuminate? If so, I believe I read that the bulb is soldered to the switch. A new switch is around $60. The switch itself works fine, it is just the illumination. Can a new bulb be easily soldered back on? Is the bulb easy to find in a store? The Honda dealership does not list a bulb replacement part for this so it would be something I would have to find at a parts store.
Thanks for any guidance you can offer,
DuBose Griffin
Old Jun 17, 2011
Re: Side Mirror Switch Illumination
you can pop it open and solder a new bulb yes. its fairly easy to do but you will have to take the old bulb to the auto store to match it. be sure it is not too bright or it will overpower the other dash lights.
Old Jun 17, 2011
CraigW's Avatar
^^^ Exactly
I took apart a neo-wedge bulb I had on hand to do mine. Try to match the size and hope the brightness is similar.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Erndog81
Oct 31, 2015 03:01 PM
AlpineCivic
111
Oct 20, 2003 07:31 PM
mwwhonda
Nov 7, 2001 07:24 PM
