Driver side door check strap
Old Mar 12, 2016
FijiEM2's Avatar
FijiEM2 is an unknown quantity at this point
Arrow Driver side door check strap
So the drivers door on my em2 doesn't stop at the indents on the factory installed door check strap. I've ordered a new one part number 72380-S5P-A01, this unit doesn't come greased so I'm wondering what long lasting grease I can put on this strap when I install it.
Old Mar 13, 2016
CraigW's Avatar
Re: Driver side door check strap
I would leave it as is with no lube, and keep it clean.
They consist of 2 super hard rubber squares that press against the black plastic rail, and detents.
Old Mar 15, 2016
FijiEM2's Avatar
Installed today, took around 15 minutes. Did NOT lube the assembly. Appears to be working just fine without any additional lubrication. I will say that the rubber was completely worn out on one side of the stopper that's mounted on the inside of the door.
willysp
22
Dec 4, 2017 09:27 PM
89hatchnewb
Apr 11, 2016 12:00 PM
cja3455
Mar 10, 2016 09:33 PM
riceburner22881
Mar 10, 2016 07:15 PM
eager2learn
Feb 29, 2016 02:54 PM
