Is it paint or old plasti dip
Old Feb 5, 2023
mkeschinger's Avatar
mkeschinger is an unknown quantity at this point
Ok, moving to body work. The beater I bought has the mirrors and trunk black. The normal color is the clover green. Here's the kicker- looks like some of what ever it is came off of some spots and the clover green is coming through. I've been trying a reducer to remove it, even lacquer thinner. The lacquer thinner seems to work, kinda on the mirrors and not making a dent on the trunk. I was able to use my finger nail on a piece that had started to come off showing the green under it prior to using the chemicals. I read that if it flakes it's paint, if it peels it's dip. Does old plasti dip flake as well? the goal was to try to only paint what I need to by removing this black stuff from the car. or should I just give in and just get them painted too?
Thanks!
The noob- M
Old Feb 5, 2023
GolNat's Avatar
Prelude Owner
Re: Is it paint or old plasti dip
Old plasti dip will peel also (I only have experienced with a few year old plasti dip). It was probably rattle can painted.
Old Feb 5, 2023
I took the sander to it- 220 grit to take off a thin layer. Used lacquer thinner after that. Looks like they did both. 1 layer of paint and 1 layer of plasti-dip.... ugh. So looks like full sanding and painting. Thanks for the help!
M
Old Feb 5, 2023
if it peels off, i would peel it off before doing the lacquer...
Old Feb 6, 2023
It doesn't unfortunately. I used some lacquer thinner to get some off and saw the under coat had a shine to it and was harder. So, kind of guessing it's dip over paint over paint...
PrYnCeQT
Jan 23, 2005 09:42 AM
Dr5D
Feb 12, 2004 09:21 PM
dru106
South Cali
May 2, 2003 05:50 PM
silverdevil
Apr 27, 2002 06:55 PM
XoULaBeAT
Apr 5, 2002 09:31 AM
