PDA
View Full Version : Overheating or loss of coolant, heater blowing cold
  1. How to I get the pipe off!?!
  2. 2001 Honda civic lx over heating
  3. Overheating
  4. coolant reservoir gets overfilled.
  5. 04 Honda civic Overheating
  6. coolant out the overflow reservoir
  7. New heater problem
  8. coolant leak on my 2005 honda civic ex coupe [solved]
  9. Through your own experience what is best liquid head gasket leak sealer
  10. Splashless funnel kit question
  11. Head gasket
  12. Civic Overheating Problem!
  13. Overheating. Cooling fan issues? Idk
  14. Reservoir boiling!?
  15. 2005 lx 1.7 non vetc overheating
  16. Something I did was wrong in bleeding cooling system [solved]
  17. Will weather interfere with bleeding radiator
  18. help! em2 still overheating with new parts
  19. 04 Civix DX, No rad fans and High operating temps
  20. Coolant splatter on front of engine
  21. Honda is overheating
  22. Overheating and heater blows cold, only when idle
  23. Over Heating 04 honda civic lx
  24. What gaskets do I need?
  25. 01 Civic EX Hole in the AC condenser
  26. No heat please help
  27. Overheating, cold then hot air
  28. Water passage gasket
  29. Coolant leak
  30. Passenger side cooling fan question
  31. 01 Civic LX Overheat
  32. Rad Fan won't come on. Did all the usual stuff
  33. found the problems. she got hot. give me your take on my plan
  34. Car seems to overheat when idling
  35. Radiator reservoir fills with antifreeze
  36. Condenser fan motor mounts melting - HELP
  37. Overheating & Coolant Loss [solved]
  38. overheat and loss of coolant
  39. 2002 Honda civic overheating
  40. Cracked block? And damage combustion chamber
  41. Radiator fans not working
  42. 2005 Coupe VP exhaust gas in coolant
  43. Has anyone tried graphite head gaskets in these cars.
  44. Copper spray vs Hylomar for headgasket?
  45. Old 50/50 coolant
  46. Weird coolant overflow
  47. Help losing coolant 02 civic ex
  48. Metal coolant hose keeps coming loose
  49. overheating when heater is on
  50. Overheating and no hot air
  51. Engine overheating after changing thermostat and both coolant temp sensors
  52. Coolant leak, please help with advice
  53. 2005 civic lx what is this coolant leak?
  54. overheating (heater blows cold when car overheats)
  55. Overheating - with a weird twist!
  56. Trying to identify which cylinder is bad
  57. Don't know what to do next...
  58. 03 LX, Junk radiator?
  59. Cooling system water still blue after four rinses
  60. Leaking coolant above crankshaft - is it water pump?
  61. 04 Civic LX OVERHEATING
  62. Engine heating up with AC use
  63. 2003 Civic Ex Overheating [solved rad fan]
  64. Head gasket opinion needed [solved]
  65. Summer coolant [solved]
  66. Steam!!!
  67. Overheating issues/mechanic stumped
  68. 03 civic ex overheating
  69. Overheating
  70. slight temperature fluctuations 2002 civic ex
  71. 2005 Civic Overheating [solved - hole in rad neck]
  72. Question about my clutch/ car In general
  73. Suddenly overheating
  74. overheat 2003 honda civic EX
  75. Thermostat Issue
  76. 1.7L Civic (Acura EL) overheating engine and boiling noise from engine
  77. Coolant flows into reservoir but doesn’t go back in radiator.
  78. D17A1 ECU with a VTEC head?
  79. Overheating 1.7L
  80. 05 Civic 5MT overheats only when I turn the heater on
  81. Over heating looking for solutions
  82. Over heating
  83. Fender Bender - Radiator bent - Overheating
  84. Head gasket questions on 2003 civic
  85. Overheating on 03 Civic LX
  86. New HG drained block coolant while at it and now coolant [solved] wont circulate.
  87. What the F#&? Is this!??!!
  88. Overheating
  89. Overheating, no coolant loss. Bogging down & sputtering after startup
  90. Mystery Coolant Smell [solved]
  91. HELP! Coolant overflowing in reservoir but not going back to radiator
  92. Temperature gauge says engine hot
  93. Overheating then no start
  94. Head gasket = P0336 ?????
  95. Odd 7th Gen Coolant Leak
  96. Water Pump Problem?
  97. Temperature problem?
  98. Overheating
  99. Coolant reservoir overflows
  100. Losing power but not overheating
  101. Overheating
  102. Mystery coolant loss [solved]
  103. 2004 honda civic dont see any leaks but im runing have to add more antifreeze heater
  104. Overheating 02 Civic Lx Coupe
  105. Coolant leak, bad smell and smoke? 2005 auto
  106. Do I need to re-torque the head after xxx miles?
  107. What a Honda Head Gasket looks like.
  108. Do they change your oil on a head gasket job?
  109. Is it the block?
  110. Odd filler neck damage, have you seen this?
  111. Machining Cylinder Head
  112. Engine overheated, header gasket blown years ago, just updating
  113. Heater doesn't stay hot consistently.
  114. Overheating problem
  115. 2005 Honda Civic overheating
  116. 01 Honda Civic EX VTEC yet again
  117. Missing coolant
  118. COOLING/SENSOR ISSUES, please HELP!
  119. Cooling fan not kicking on
  120. 2005 civic ex..back presuring and losing coolant
  121. Looking to buy car, but has odd overheating issue.
  122. is 2003 Civic with 105k worth a $1300 head gasket fix?
  123. Strong smell of coolant, not loosing coolant
  124. Overheat/No heat
  125. Risks of a head gasket job on a high mileage engine that's overheated a lot?
  126. 2004 Honda Civic VP 220,000 mi overheats randomly and cools down
  127. Trouble with overheating
  128. 01 ex blowing white smoke and misfiring
  129. Coolant loss
  130. Overheating don't know why
  131. Overheating While Idling
  132. Overheating issues / Fans not working
  133. overheating issue
  134. 2004 civic temp goes up after I come off the highway
  135. Overheats but doesn't over heat.
  136. 2002 EX Overheating when stuck in traffic again!
  137. Cooling and AC fan help
  138. help lol
  139. 02 civic head gasket
  140. Coolant Connecting Pipe Removal
  141. Over Heating Issue
  142. 2002 Honda Civic overheating
  143. ac belt snapping and coolant disappearing
  144. Buying a 2003 with no hot air?
  145. Head gasket issues after rebuild
  146. Coolant frm radiator coming off pressurised on opening radiator cap when the car cold
  147. water passage gasket
  148. 2004 civic - 2 doors. Coolant drain bolt in engine block
  149. Coolant type question
  150. Loosing coolant?
  151. Need advice for what to do please
  152. Gauge, Overheating, I don't know what's happening help.
  153. Boiled coolant, gauge reads normal, code for intermitent timing sensor issue.
  154. coolant expansion tank overflow
  155. Using Stop Leak for headgasket problems
  156. Coolant loss when parked
  157. Coolant loss
  158. Overheating only at high altitude
  159. Overheating
  160. 2005 Honda Civic Overheating/low coolant
  161. Head Gasket Leak 2001 fixes
  162. Overheating Diagnosis Help
  163. Serious overheating problem
  164. Overheating
  165. Overheating issue 02 civic ex
  166. New to forum! Need some help
  167. Overheating,lost of coolant,heater not blowing heat.
  168. Overflow tank overfill, radiator empty
  169. Overheating Problem
  170. 2004 Civic LX Coolant odor when stopped
  171. prevention of the common overheating issue (faulty parts)
  172. Any tips on cleaning out head bolt holes?
  173. Cooling fan issue....please help!
  174. Head gasket kit - mystery parts
  175. overheating
  176. Coolant loss by the radiator cap`
  177. 2004 civic is STILL overheating
  178. To fix, or not to fix...
  179. 2004 civic started doing a bunch of bad stuff
  180. Mechanic didn't tighten radiator cap
  181. Overheating Issue
  182. 2004 Civic DX issues
  183. Overheating Situation, then no issues?
  184. 2002 Civic 1.7L OverHeating
  185. Overheating and temp gauge issue.
  186. Misterious Cooling Problem.
  187. Overheating 2004 Civic
  188. 04 Civic LX pushing coolant out of the overflow tank
  189. HG Test - Pressurizing Cylinders - What could I do wrong?
  190. 2003 honda civic overheating and leaking coolant.
  191. Overheating still after replacing head gasket, water pump, and thermostat
  192. Radiator overflowing but compression good
  193. Overheating Issue: 2003 Honda Civic EX
  194. Slow leak or blown head gasket
  195. Trouble diagnosing issue
  196. Overflow tank full
  197. Everybody says head gasket, please help!
  198. How hot to warp the head?
  199. d17a2 overheating problem and not be able to rev past 4k
  200. 2002 honda civic lx
  201. 02 Honda Civic Overheated and leaked anti-freeze and now won't stay on.
  202. Car overheating
  203. Overheating in minutes, top rad hose is piping hot and lower rad is cold?
  204. car overheating but coolant is full?
  205. Mysterious coolant loss
  206. Overheating only on long distance trips
  207. Overflowing antifreeze reservoir
  208. Overheating and Coolant Loss Problem
  209. Radiator issue (Is this car totaled)
  210. First Post - Overflowing Coolant Overflow but good HG?
  211. My 2002 Honda CIVIC Overheating
  212. Discussion - causes for head gasket leakage
  213. Are my fans only suspoed to come on with the A/C on ????
  214. Confirm my "Needs a head gasket" suspicion?
  215. 2002 Civic EX Head Gasket Help!!!!
  216. overheating with no heat and coolant loss/overflow
  217. 2005 Honda Civic LX 1.7L SOHC Overheating - Head, Gasket problems?
  218. 2002 Civic Overheating Problem!
  219. Help! Overheating!
  220. Stalled !!!
  221. Engine overheating!!! Help needed troubleshooting!!!!!
  222. Rad fans not kicking on - its not the switch
  223. 02 Civic Lx Getting warm
  224. My car is running hot, advice would be greatly appreciated
  225. 2001 civic d17a1 4 dr A/t
  226. Over heating after head gasket?
  227. Keep losing coolant after timing belt job
  228. Cooling issues/temp sensor question
  229. Overheating
  230. This look like evidence of a blown head gasket to you?
  231. Overheating ? New radiator?
  232. Headgasket problem but wondering about the egr system
  233. Radiator coolant overflow issue. stuck thermo? blown water pump?
  234. Temperature guage goes to 3/4 and then back to "normal" during driving
  235. going in, any other parts to the list?
  236. Overheating and mysterious coolant loss common causes - reference
  237. coolant system problem
  238. Headgasket replacement parts list
  239. No heat?
  240. Civic 02 strange Overheating
  241. 2003 Civic EX Overheating Issues
  242. 01 Honda starts to overheat at high speed
  243. Car overheating after thermostate replacement
  244. 02 EX Coupe Intermitent Overheating
  245. 05 civic coolant leak
  246. No heat/overheating Again!!!
