Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Temperature problem?
Old Apr 11, 2021
HaCiv's Avatar
HaCiv is an unknown quantity at this point
Hi, i’m new to this forum so im if this is in the wrong category.
I just bought myself a 2002 Honda Civic 1.4I VTec and im having some issues..
So first off:
my tenperature gauge needle is always standing halfway, even before I put the key in the ignition, what could this be?
Number 2:
after every drive and opening the hood I notice coolant all over my engine,coming from the pressure cap.
if someone could help me out it would really be appreciated!
thanks for reading
Old Apr 11, 2021
FRSam's Avatar
Click Here
Re: Temperature problem?
Coolant coming from the overflow reservoir on the left side of the engine bay? That’s a bad head gasket.
Old Apr 11, 2021
HaCiv's Avatar
even when there isn’t any white residue on the oil cap?
Old Apr 11, 2021
FRSam's Avatar
Click Here
Yes. If any coolant is overflowing at all (unless way too much has been added), it’s a bad head gasket.
Old Apr 11, 2021
HaCiv's Avatar
Well that really sucks.. I’m waiting for a new overflow cap to be delivered and really hope that’s at fault, otherwise i’ll have no choice but to replace the gasket.
would you also happen to know what causes my gauge needle to be stuck in the middle?
even when I don’t have my key in ignition its halfway. Is this a Dashboard problem or the themostat?
I can’t find the anwser tot his anywhere so I would really like to know..
thanks for the replies
Old Apr 12, 2021
BrotatoChip's Avatar
Super Moderator
For the coolant temp gauge, the needle could be getting stuck. You'd have to investigate. If the back panel/sheeting of the cluster is sticking up it can prevent the needle from moving.
Here's more info on the head gasket:
https://www.civicforums.com/forums/3...reference.html
blazebrown
18
Jun 2, 2019 12:31 PM
wwhitby
Nov 17, 2018 11:40 AM
2002civic2002
Jul 12, 2018 09:01 AM
MPGhound
Oct 9, 2014 01:03 PM
streetneons
Jan 5, 2011 07:19 AM
