Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Temperature gauge says engine hot
Old Jun 27, 2021
Debbie Van's Avatar
Debvan
Debbie Van is an unknown quantity at this point
While trying to find out the reason my car gets hot and temperature gauge rising I got a new radiator but it was not filled correctly. The guy filled it with only half gal coolant and sent me on my way. He also broke hood release and it was 150 miles before I could get hood open to add more coolant. System wasn't burped. Honda civic 2005
Old Jun 27, 2021
Re: Temperature gauge says engine hot
you should have returned to the guy doing the job and have them correct...
also, potentially can be headgasket failing
Old Jun 27, 2021
Debbie Van's Avatar
Debvan
He left town
Old Jun 27, 2021
there are two videos in the first post here.
take to a shop and ask them to do those tests. That should show if headgasket or not.
https://www.civicforums.com/forums/3...reference.html
Old Jun 27, 2021
other types of tests won't work on these engines, so don't waste time or money on them, just the air pressure in the cylinders shown the videos work.
Old Jun 27, 2021
Wankenstein's Avatar
Sounds like that mechanic is a putz. First off the dash temp reading could be faulty and the way to verify coolant temp is to insert a high-temp thermometer in the radiator neck from cold start to operating temp and above. The other method is to use an infrared heat/temp detector aimed at coolant hoses and radiator.
Reason for overheated coolant system:
*Thermostat stuck closed
*Failing/failed water-pump. They can partially fail without leaking and will not move coolant fluid as rapidly as they should.
*Clogged radiator. Leaking radiator causing excessive fluid loss.
​​​​​​* External or internal (into cylinders) leaks.
* Breached head gasket.
Danny Heredia
Sep 24, 2019 08:23 AM
99hondamar
Aug 27, 2017 07:49 PM
Walter_1980
Aug 17, 2016 08:56 PM
atkinson40
Sep 19, 2012 01:26 AM
dajackal
Buy, Sell, & Trade - Archive
Mar 13, 2007 08:58 PM
