Overheating
Re: Overheating
What do you mean radiator? You measured flow through and used thermal imaging to check for blockage?
What about coolant level?
Was the thermostat tested?
Are the fins of the AC condenser degraded?
Are you using 50/50 coolant mix?
Re: Overheating
What do you mean “water pump”? You just replaced it with a brand new OEM pump that the impeller can’t spin off on?
Re: Overheating
My point exactly is you seem to believe every part you have is fine, but your car is overheating due to some mysterious reason.
Your car literally cannot overheat when all those parts you listed are working correctly.
So, by trying to understand what qualifies you as being able to determine a part is good, I can spend my time giving you direct suggestions.
My first though is you bought a crap waterpump and the impeller is slipping/ broken/ poorly designed flow characteristics..
I asked you directly if you installed a new Honda pump.
Now if you answered, yes Slumpert, I replaced the waterpump with a actual OEM Honda bought unit when I did my timing belt job. I would go onto my second though that the radiator was junk.
But instead of answering my actual question, you wrote “Water pump is a water pump”..
No, cheap *** waterpumps fail the cooling system by allowing the impeller to slip, fall off, bad flow design, simply wrong size.
Indeed, I am a snob when it comes to people using cheap parts for critical areas of the car.
What are the chances you or the previous owner poured a bottle (or more) of stop leak in the coolant?
Re: Overheating
Your cars’ issue is poor coolant flow.
Cooling fans shutting off while car is over heating and car still overheats when cooling fans are forced on = poor coolant flow through radiator.
Waterpump, thermostat, radiator.
One or more of those items is not working to spec.
If this was my car, I would
Spend $30 for a actual Honda thermostat.
Spend $90 for a amazon brand radiator
Spend $15 for a actual Honda radiator cap.
No one here is going to “parts cannon shame” you for replacing those items as even if they were not the issue, they are due for replacement at 15+ years old.
If it was still trying to overheat on me (and still not losing coolant / forming air pockets in radiator) I would replace the water pump with a actual Honda water pump $75.
01candycivic
Oct 12, 2006 06:52 PM
