Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Misterious Cooling Problem.
Old Sep 22, 2018
ElToro626's Avatar
ElToro626 is an unknown quantity at this point
Help Please!
2002 Civic non vtec.
My radiator hose get swollen at low speed and idle.
Radiator fans working.
If I drive at freeway speed overflow tank gets full and little bublees are visible car overheats at street.
If I turn on A/C fans, tempeture goes back to normal radiator hose gets soft and no more bublees.
When car cools off, antifrezze return to radiator from overfill thank. Please help.
Old Sep 22, 2018
Slumpertcivic's Avatar
Re: Misterious Cooling Problem.
Replace it with OEM Honda Hose
Sounds exactly like failed headgasket, compressed air test into cylinder needed to absolutely make sure.
How inclined are you to work on a car?
Old Sep 23, 2018
Wankenstein's Avatar
Agree
Actually, when it comes to 7th gen 1.7L engine there's nothing mysterious about a blown headgasket...
Old Sep 30, 2018
dsm482's Avatar
dsm482 has a spectacular aura aboutdsm482 has a spectacular aura about
headgasket
Old Sep 30, 2018
DOES return and the radiator stays completely full? Are you positive about this?
The radiator level is supposed to stay completely full to the top at all times. It doesn't take much fluid loss at all to compromise cooling efficiency (overheat)
Replace swollen hoses
Make sure radiator fans actually operate when the coolant temperature is hot enough.
Subs
Jul 26, 2019 06:49 PM
pinehilljoe
Dec 6, 2017 11:17 AM
Hani4g
Oct 31, 2015 02:09 PM
cferry7
Oct 3, 2015 04:33 PM
Camaromanz
Sep 13, 2014 07:32 PM
