Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Civic Overheating Problem!
Old Aug 26, 2024
Sweeethearts82's Avatar
Sweeethearts82 is an unknown quantity at this point
My son has a 2002 honda civic ex model 1.7 he was having an issue with overheating and we saw fluid there the waterpump is. He is a YOUNG diesel mechanic but he does a good job. We recently replaced the water pump, timing belt, thermostat and cam shaft sensor. Oil is clean and no visible leaks on the radiator yet hes still sometimes having issues running hot. I feel we buy too much coolant. I mentioned blown head and he swears since there is no white exhaust smoke, no cloudiness to his oil that the head isn't blown. Someone please help it's 106 out in texas and he already doesn't have A/C
Old Aug 26, 2024
Colin42's Avatar
Re: Civic Overheating Problem!
It's the headgasket, theres a test where you apply compressed air to the cylinders and it will push air into the coolant
Old Aug 26, 2024
so there's no white s.oke anywhere and no cloudiness to the oil...still think it's a head?
Old Aug 27, 2024
video is on the first post. It is pass or fail test, worth more doing the test than arguing about
https://www.civicforums.com/forums/3...reference.html
Old Aug 27, 2024
BrotatoChip's Avatar
Super Moderator
White exhaust smoke would be the engine consuming coolant. Milky oil would be coolant and oil mixing. The common head gasket failure is neither of those. It's combustion gases getting into the coolant, pushing it into the reservoir. This means there's less in the cooling system, causing an overheat.
2002civic2002
Jul 12, 2018 09:01 AM
Sep
22
Jan 29, 2016 01:06 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
PoopyWeen
Jun 10, 2015 08:21 PM
arizaga8799
Oct 17, 2012 09:24 PM
